Question about Apex Digital PF3225 32" TV
Apex pf3225 picture is to wide for the screen
There is no adjustment in the regular tv menu for picture size. is there aome kind of service code for this model?
I was able to get a good picture by doing the following. Using your PF 2025-3225 remote:
Press the volume to zero
Pressmute on the remote and hold (tv should say mute)
hold the menu buttuon on the tv
There are 10 menus as you press the arrow buttons, go to the first with anything "H". you will use the "e/wide" and "H" item also Trapzium and the parabolic setting and slowly use these until you get the desired quality.
The go to the "V" menu and adjust carefully until you get the desired quality. Do not adjust anything that is already set to 1 or 0, If you do and you get a blank or lined acreen just press the opposite arrow and it should go back to your picture.
Power off and on after you see a good picture.
You could use your cable guide or DTV Playlist as your picture as they have alot of items in the corners. that is how I did it, it worked for now.
Posted on Apr 04, 2009
    Genius:
  • 1,139 Answers
This problem is called blooming, it is caused by poor High Voltage regulation. It denotes a possible problem with the IHVT (Integrated High Voltage Transformer), or the HOT (Horizontal Output Transistor). I would suggest that you have a qualified TV technician troubleshoot and repair this problem.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 09, 2008
  • 27 Answers
Check the +B voltage in the primary power section, if it to high you picture will show bigger
Posted on May 27, 2014
I got a apex tv model pf3225 the pictures to big how do i adjust it
To adjust the picture parameters, you have to enter its service mode. If you wish to get some details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Timeslide / Flipcard, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Service mode entry, adjust and exit procedure to many popular brand TVs are given in detail.
Never try to enter the service mode, with a universal remote control. It might make wrong adjustment parameters, which you can't even make it right. The original remote control should be used for this purpose.
Nov 12, 2013 | Televison & Video
Apex Tube tv
check your screen menu and check screen size should say normal, wide screen and cneima . change to a smaller screen should bring everything in line
Feb 08, 2013 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Unlocked my apex tv but now it only shows blue/static screen. Help!
The chroma processor section should be troubleshooted. It is a skilled work.
May 17, 2012 | Apex Digital PF3225 32" TV
Apex model PF3225, The TV is Locked (blue screen with red key on the bottom left corner). Don't have original remote...please help
Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
Mar 22, 2012 | Apex Digital PF3225 32" TV
I have a JVC I'ART 27" TV. Model # AV 27F485. My screen is in wide screen. When I play video games or movies everything on each side of the screen is past view. I went to the menu but can't find out...
Hello
Hit the "Menu" button surf through and enter "Picture settings' screen. There you can see various picture adjustments options. Just press "0" [zero] button on your remote, will set all the picture settings factory levels, and will solve your probelm. OK.
Mar 30, 2011 | JVC Televison & Video
No matter which picture size I select, I cannot ever seem to get the picture from the DVD to fit the screen. For instance, I am watching a DVD right now that is in wide screen, and when in...
U tries used the DVD player remote to fix this problems,could be the DVD movie?Have the same problems,with the regular tv incomming broadcasting signal?Yes,than the tv Tuner signal board is the problems and the causes it dying and shorted.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 27, 2011 | Sansui SLED2280 22 in. LCD TV
Service menu
The volume on my tv just stopped working.
Apr 15, 2009 | Apex Digital GB51HD09 51" Rear Projection...
Rca Model R56WH70 Tv. Problem: Unit switches between wide screen & regular size picture on it's own. When watching this tv, picture just changes size on it's own.
you have the auto format on! the tv is working correctly, go into the user adjustments and turn off auto pic size
Oct 08, 2008 | Televison & Video
Where do I find APEX parts? 32" PF3225 sound card
Hallo,
I have a Apex Sound Card.
If you need it send me a mail.
Mar 14, 2008 | Apex Digital AT3208S 32" TV
Cannot make horizontal and vertical size and position adjustments
OK...I paid a whole $50 for an Apex AT2702 that had [undisclosed] vertical zoom, horizontal shift, vertical shift and width issues. Before I raised hell for the person who sold it to me, I decided to first exhaust all alternative solutions.
I found that in order to tweak these settings, you have to be in service mode and must have a service manual which I can email upon request.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE !!!
1-Reduce your tv volume to 0
2-press the MUTE button on your original tv remote [you'll see "Mute" in red on the screen]
3-AT THE SAME TIME, press MUTE on the same remote and MENU on the tv controls.
This set your tv into service mode [there will be a red "S" at the top-center of your screen.
You'll need the table in the service manual page 47 where there are V-SHIFT, H-SHIFT, V-ZOOM, E/W WIDE default values that will need to be changed. WATCH YOUR SCREEN as you change the values to ensure you don't over do it.
If you have news ticker and sports scores issues, you'll want to be tuned to CNN, FOX, ESPN or whatever to see how your changes are applied.
If you have tv guide problems then tune to that channel or press info and see what happens when you make the changes.
BE SURE TO DOCUMENT YOUR CURRENT SETTINGS SINCE ANYTHING YOU CHANGE WILL AFFECT YOUR SET'S PERFORMANCE.
This has worked for my set and you may attempt this solution on yours at your own risk.
I'm no longer pissed off that I got a bogus tv because it now works just fine and I can see everything!
Good Luck!
Jul 31, 2006 | Apex Digital AT2702 27" TV
Apex Digital PF3225 32" TV Logo
441 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
