Question about Refrigerators
Semi automatic defrost button won't pop up
Whirlpool model EL1WS semi automatic defrost button on door of refrigerator won't pop back up...refrigerator won't turn on after defrosting. There is no manual because this is a rental apartment and landlord is away.
  • Anonymous Mar 14, 2014
    model number 25351699100
    Kenmore model 25351699100
  • 750 Answers
The switch is broken and needs to be replaced.
This happens a lot
Huum
Please remember to leave feed back .
This is the answer.
click solve please1
Posted on Dec 09, 2008
FREEZER SIDE OF SIDE BY SIDE FREEZES UP
You have one or more of your defrost components that are bad. Namely defrost heater, defrost thermostat, and defrost timer / board depending on model.
Nov 04, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge compressor will not kick in
call your parts store,give them the model number,open the fridge door on the right hand wall up near the ceiling you'll see a tag with the model number,tell them you need a start device and they will sell you one.do you hear a clicking sound or smell anything,when my device went i could smell it.unplug the fridge,remove the bottom panel in the rear and on the compressor you'll see a clip,pop it off,slide the start device off,shake it,if you hear pieces rattling around inside it,it's bad,leave the wires on until you get the new part.next time send the model number,a bad timer,board or cold control could also cause this.if the machine gets stuck in defrost the compressor won't run.if you open the freezer door and the fan is blowing,it's not in defrost and most likely it will be the start device.hope this helps.
May 07, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
My ED5HHAXVQ02 refrigerator is not cooling. However the freezer is overfreezing and frost is building up.
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer/refrigerator
Refrigerators with an evaporator (called a humid plate on this type of refrigerator) in the refrigerator section are called a semi-automatic defrost. This means that the freezer section occasionally needs defrosting but the refrigerator section defrosts by a means called "heat leakage defrost". How it should work....
the cold control, (the electrical device under the dial), leaves the compressor off for long enough for the plate to melt off each cycle.
If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help
Oct 07, 2008 | Frigidaire Freezer Refrigeration White...
Whirlpool gold GS6NBEXRL01
hi .thanks for the question . the defrost cycle is probably on. either that or a faulty thermostat. thanks the appliance doc rate me please
Sep 10, 2008 | Whirlpool GD2SHGX Refrigerator
Refridgerator temperature
I think it may be a defrost system problem. If you have frost on the back wall the problem is related to the defrost timer or defrost heaters or thermostat.
Also check the condenser for dust. If plugged with dust the system can not get rid of the heat. If dust is present clean it out completely.
Remove the toe plate under the refrigerator door to check the condenser.
May 24, 2008 | LG Refrigerators
Refrigerators Logo
1,037 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
