Question about Gold Medal 2086 Popcorn Maker
Trips circuit when you turn on the Kettle heat
We have a Gold Medal Popcorn maker, Model 2388, about 4 months old. Everythime we turn on the kettle heat it blow the circuit. Is there a fuse that needs to be replaced or the thermastat?
  • Anonymous Dec 25, 2008
    when the kettle is on the trip switch goes off? How to fix it
  • 21 Answers
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
Posted on Dec 16, 2008
Adjusting the thermostat for best temperature
There is a adjusting screw on the thermostat. So your not guessing you should heat it on a. Bench with a amp meter on the line . Then check temp and adjust from there. The factory thermostats are. Preset . If you installed the correct one adjustment should not be necessary? Is the element tight on the bottom?
Jul 30, 2016 | Gold Medal Products Gold Medal 2388 8 oz...
Trying to find kettle wiring drawing 3255
To order a manual from the factory the part# is 67834. Depending on how old this is , those kettles and or similar design had a issue with the nut comming loose that holds down the thermostat thight to the bottom of the pan. The loose nut would then bounce around in there until it touches a elect.connection and ground at the same time. It will short circuit the kettle and end up welding itself in place . so when you turn the kettle on it trips the circuit rite away. you have to dissasemble it and remove it . there is a new locking type nut avalible to replace it.
Jan 11, 2016 | Gold Medal Kitchen Appliances - Others
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
Popcorn maker worked great for a matinee then for the evening show the kettle no longer heated up
Your kettle has had a ground fault, and damaged the switch in the process. Do not Continue to Try and use.
Take the kettle to a gold medal dealer, and replace the switch in the cabinet.
Jul 20, 2014 | Gold Medal 2003 Whiz Bang Popcorn Maker
Gold Medal Deluxe Pinto Pop Popcorn Machine Model 2147 will not heat up
If the switch is OK and you have. Power at the kettle plug and you are not getting any heat it's one of 3 things. Burned wire inside the kettle. this is common. Or it could be the thermostat is bad or the element itself is out?
May 07, 2014 | Gold Medal Products Gold Medal 2147 120208...
How to install a stir rod in a Gold Medal Product, Deluxe Pinto Pop, model 2147
Take the kettle crossbar assy off the kettle and look and see if there is a set collar above the shaft weight. If so loosen it so you can slide the weight up...enough to get the old one out and the new one in.
Mar 31, 2014 | Gold Medal Products Gold Medal 2147 120208...
Kettle not heating up
First check that the kettle is plugged into the cabinet. Then check if switch, (or red power light) lights up when you flipped the switch back and forth. If it does the problem is inside the kettle.
Contact a Gold Medal dealer for service options, repairing it is the best options as a replacement kettle for that model is very expensive.
Sep 07, 2013 | Gold Medal 2001ST Silver Streak Citation...
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
I have a Gold Medal Popcorn Machine 2086. The kettle is uncleanable. Where can I purchase a new Kettle?
I hate to put this as a solution because it really isn't. I have an old popper needing a new kettle and was told it was almost as much to purchase a new kettle than the whole machine. The kettle is almost the entire cost of the unit. I will be purchasing a new unit.
Apr 08, 2009 | Gold Medal 2086 Popcorn Maker
Gold Medal 2086 Popcorn Maker Logo
596 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
Ted Maxwell
Coss
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
