Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinking Green Light
I'm an old TV repair guy and was asked to replace the four caps. on the erring board in the Mitsubishi rear proj. TV. I did so. Double checked for solider bridges, put the board back in..nothing comes up. There is power to the set, I checked all connectord, grounds, etc.
Any ideas??
Tony
  • zilcht Dec 13, 2008
    "Phil",
    Thanks for the hint but I think it was the DM board I changed the four caps on. It was the vertical board on the left side of the chassis.
  • 179 Answers
Most of the time it is not just the 12 caps( there are 4 each on the DM FMT and PWR boards) i repair these all the time.
www.tv-techs.com
Posted on Dec 14, 2008
    Problem Solver:
  • 6 Answers
Check ur dm board it could have caps as well
Posted on Dec 13, 2008
I TOOK APART THE TV TO MOVE IT DOWNSTAIRS AND it worked great for 10 minutes and then shut down. I have the code and it is green and 2 and 2
That is called the "Parpadeo luz verde de la muerte" or Blinking green light of death. You may want to make sure all the wires are tight first and that when you moved it a cable wasn't seated. Instead of replacing the capacitors, your situation sounds more like bad solder connections on the DM module. Here is a link to a web forum where they talk about this exact problem.http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens.html Blinking Green Light of ***** frequent prob Mitsubishi rear proj...
Jun 25, 2015 | Mitsubishi WS-65413 65" Rear Projection...
I have a 60 in. mitsubishi hdtv. i just got it and the tv wont turn on and the green timer light kept blinking. now the green light wont even blink. thank you
Send an email to Paul on this Hi Def forum and he will send you detailed instructions for repairing your set inexpensively. Hope this helps
http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens-5.html
Jun 01, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Green timer light justs blinks and the tv will not come on
I have a Mits rear proj screen ws-55613 replced the 4 caps on the DM and still have th fast blinking green LED any Ideas?
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Blinking Green Light Mitsubishi TV
the problem is in the DM module there are caps that break down and vent and cause this problem
the caps are replaceable we use a higher temp and grade cap in servicing them
but i understand a place called tv world .com sells these kits and a cd on how to if you have the tools to do this
Oct 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I had the power supply replaced, but didn't solve the problem. Turns out multiple issues were at play. Only thing that solved the problem was to the have the chassis pulled and rebuilt by Mitsubishi. If you are insistent enough they should do it for free, minus the labor for removal and re installation (approx.$300)
Oct 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light under timer
I can almost guarantee that the circuit board(s) have bad capacitors on them. I repaired one last week that had 20 bad capacitors on 4 boards.
Fixed one the week before with 15 bad caps on two boards.
A repair shop may be able to replace the boards, but it may be expensive.
- I hope my diagnosis is wrong-
Sep 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mits 525 started blinkng green standby light today makes a muffled sound as it beeps. wont turn on just beeps.just under 4 yrs old. have replaced bulb 3 times. reading some of these posts seems like...
The first generation mitsubishi V26 chassis which is what your model is has a bad habit of failing capacitors. The steady blinking green power light is related to the DM not completeing the boot up sequence. You can get the V26 DM repair kit at the following link which contains the replacemnent caps that are prone to fail and has the CD with step by step instructions on how to duisassemble the cjassis and replace the caps. Its very inexspensive and will usually repair that issue. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Mar 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green light flashing
this means the DM board is not booting up. You will typically need 4-8 capacitors to fix this issue. you have to pull out the board and solder in new parts. let me know if you feel skilled enough to do this and I can give directions. The caps will usually bulge at the tops and are 1000uf .. mitsubishi recommends replacing with 680uf 16v caps..
Jan 02, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Hmm I tried unplugging it for a while but I will try this again tonight since it will be unplugged for about 24 hours.
Thank you McColp for the info..
I have a service guy coming tomorrow, maybe this will work before he comes! I appreciate your help!
take care
Maria
Oct 26, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
