Smeg se 355 cucina oven wont turn on but the hob works
barkencoa
  • 3463 Answers
SOURCE: smeg oven does not turn on - the light and the fan work but
Is the hob seperate from the oven? if it is then I suspect the problem is witb the oven, you need to check the supply to the oven to make sure you have got voltage, if you have then the prob is within the oven, and this could be one of several things
Some single ovens are sometimes plugged into a normal socket, in which case you need to check the fuse in the plug.
Hope this helps.
Plz leave feed back.
Ta.
Posted on Dec 09, 2008
BIKER T
  • 909 Answers
SOURCE: Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Posted on Sep 20, 2009
MNfisherman
  • 11896 Answers
SOURCE: Smeg A2 cooker, 11 2years
Is this gas or electric? If it is electric, you will want to test the power to the burners with a voltmeter. This will tell you if the control is bad and not giving power to the burner, or if the burners themselves are bad or possibly just loose or corroded connections.
If you have gas, check the gas valve and the tubing. Make sure there are no holes or gaps letting out the gas, make sure the valves is completely up to allow full gas flow. Also check that the tubing is clean of debris.
Posted on Oct 18, 2010
SOURCE: how do i change the volume on the oven timer? i
whilst alarm is ringing press the minus (-) button. there are 3 volumes to choose.
Posted on Feb 11, 2011
paulcharmbur
  • 744 Answers
SOURCE: Smeg oven and hob ubit:
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Posted on Mar 05, 2014
Knobs on oven
"Smeg parts" search on Google.
Model, serial and a photo will help when you find your local service agent.
Oct 17, 2013 | Smeg Cucina SE375 SS Oven
Knobs on front of oven
Google "Smeg parts"
Find your local service agent.
Smeg oven UK80MFX1 troubleshooting
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 30, 2011 | Smeg Ovens
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
Jan 14, 2011 | Smeg Ovens
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Sep 20, 2009 | Cooktops
Smeg oven does not turn on - the light and the fan work but
Hope this helps.
Ta.
Dec 09, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven and hob ubit: Fan works but oven wont heat up
Oct 05, 2008 | Smeg Kitchen Ranges
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
