LCD TV picture has vertical lines through picture equal spacing
On screen menuing not affected but any input has the lines they change color with back ground red on black and change as picture changes. It looks as if it is losing interlacing. Hapened all at once. distance between lines change with different screen size and go from 1/16 of an inch to very thin the smaller the picture.
  • maudesterfra Dec 09, 2008
    have a dark film section on the bottom of the screen
  • Anonymous Jan 03, 2009
    Same issue. Darker section on bottom 1/3 of screen
    Problem Solver:
  • 28 Answers
Call 323-767-6030 and I will go through with you.
Posted on Dec 09, 2008
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Hi I have a 55 inch LCD TV that while I was watching TV it went completely black when I turned it off and the on again there were rainbow vertical lines moving across the screen then at some points there...
My first thought would be to check your TV on multiple inputs to verify that it IS the TV and NOT isolated to your input cable(s). If you can get a solid blue color to come up on the screen by changing inputs then it would really narrow down the issue(s).
Hope this helps.
Jan 04, 2018 | Insignia NSLTDVD26 LCD TV
Have a blue vertical line that goes from the bottom of the picture up about 12" and about 3/16" wide. Located 12" in from the right side of picture that won't disappear.
if you still have line when you change your inputs and if it affects the menu most likely the lcd panel is bad and will need replacement. If not under warranty the panel will cost more than the tv did.
Jul 03, 2010 | Vizio L32 32 in. LCD HDTV
Vertical lines half way across screen.
Try performing a factory reset of the TV2_bing.gif. Go into the service menu (Press, then release the INPUT button on the remote, then key in 2580). Scroll down to "Other Settings", then go to "EEPROM Init", then press enter, select YES and press enter. This will reset the TV to the factory defaults. If that does not work, send it back for repair. Good luck!
Jan 12, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Yellow line on left side of screen-
If this is only happening on one input like your cable input and the dvd player is working great on a different input, then the issue can possibly be signal related and not a problem with the tv, if this haapens on any input you are watching, check to see if it affects the menu if it does then your looking at a Logic board issue, if it doesn't affect the menu but happens on multiple inputs then you have to replace the signal board
Aug 18, 2008 | Philips 42PF7421D 32 in. LCD HDTV
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
643 people viewed this question
Top Televison & Video Experts
