Question about LG LDF6810 Built-in Dishwasher
I have LG 3 years old dishwasher. Upper arm does not spin. The repair guy replaced the pump, but it still did not resolve the problem:(
  • 423 Answers
If it works now, please report back what was done to fix it. If not, are you getting an error code?
Did service guy replace the motor? The impeller? The mesh filter?
Posted on Mar 30, 2009
How do I remove spin arm assembly from my kitchenaid dishwasher
About 56,200 results (0.83 seconds) Search Results
    How To Repair Dishwashers/KitchenAid Repair/Chopper ...
    https://en.wikibooks.org/...Dishwashers/KitchenAid.../Choppe...
    WikibooksDisassembly guide to access the chopper assembly in: KitchenAid K seriesdishwasher (similar to Whirlpool and Kenmore models) ... If the door safety interlock fails, the dishwasher could return to an active mode where these blades spin and ...place and carefully work around it to remove the upper spray arm water conduit.
    How to: remove and clean your dishwasher spray arms ...
    ? 3:13
    https://www.youtube.com/watch?v=MCWvxGmK3eM
    Feb 1, 2013 - Uploaded by Indesit Service UK
    Watch our easy to follow guide on how to remove and clean your Indesit dishw... ... KitchenAid & Whirlpool Dishwasher - Not Cleaning ,pump wash arm impeller chopper ... Why am I getting poor results from my dishwasher?
    Dishwasher Not Cleaning-How to Remove Spray Arms ...
    ? 3:47
    https://www.youtube.com/watch?v=BIru-ieAK54
Feb 03, 2016 | KitchenAid Dishwashers
Both lower and upper arms not spinning. Checked everything else. Also I have had this fault twice before in the last x2years. But never both arms at once. Repairs are costing me more than the price of...
Hi sixsister501,
Firstly check the spray arms - especially the holes where water would flow through (The Spray holes), usually these holes are clogged by dirt etc. Clear them with ear-buds and toothpicks.
If they are clean, it could be that your Circulation Pump has gone (Most likely actually), then I would advise you to purchase a new Dishwasher. They tend to be between 25% and 60% the price of the whole machine.
Hope this helps, hope it is only the holes :-)
Kind Regards
Jedemeyer1
* If you found this solution helpful, please rate it.
Jun 08, 2011 | Dishwashers
LG model LDS4821ST.... Top and Upper spray arms arn't rotating.
I have an LG LDF8922ST model with the same exact problem (16 months old as well). I think you are right about the vario spray system. Seems like the repair guys that come out are clueless and get very little assistance from LG customer assistance. I will never buy another LG product again.
May 28, 2010 | LG 24" XL Tall Tub Built-In Dishwasher -...
TOP SPIN ARM NOT SPINNING TO CLEAN TOP RACK OF MY KITCHEN AID DISHWASHER. IT IS ONLY 1 1/2 YEARS OLD AND MY TOP TACK IS SUDDENLY NOT CLEANING
Hi.
First ensure that the arm is not getting stuck, and check that the orifices are free.
When the top arm is not spinning you may need to replace pump and motor assembly. First it is good looking for blockage in pump hose.
If the appliance is less than two year old, then it may be covered by limited warranty. Call Kitchenaid at the number listed in the owners manual to verify your warranty status.
Regards.
Nov 20, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Top arm in dishwasher will NOT spin!
When you say the top arm does not spin, remember that the LG model x811 family has the Vario feature that alternates between routing the pumped water to the bottom arm and then the top arms alternately. So anytime the dishwasher is washing and rinsing, either the lower or upper arms will be spinning.
If the problem is not above, then the motor that drives the check valve may have failed (or the check valve is obstructed inside.)
Hope that helps. Please post back here with what you find, OK?
Sep 04, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
When the cycle is finished the dishes arent washed, in particular the ones on the top rack. Ive removed the arm that carries the water to the top sprinkler to see if its blocked and it seems to be OK.The...
Being from the US, I have not worked with this LG dishwasher, not any down under.
But the first thing to do is use only a name brand dishwasher detergent powder. Don't use gels or tablets, ever. Many cleaning problems are resolved by avoiding the ultra cheap generic detergent.
If problems continue, confirm that the heating element is still working. Dishwashers need heated water to activate the soap.
If problems continue, my next move would be to remove the gear beneath the lower spray arm and clean everything and remove debris that could be blocking the water flow.
Good Luck!
Apr 08, 2009 | Dishwashers
Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Apr 01, 2009 | Dishwashers
Whirlpool 6600 24 inch dishwasher: low pressure,arms not spinning
Your water pump is blocked. You will need to either call a repair person or disassemble the top of the pump (inside the dishwasher, bottom) and check the water input duct. It just might be some food, etc.. that is blocking the input. But if you don't see anything then it will be further inside and will need to be removed and cleaned. BIG pain...
Best of luck. BTW, I've had the exact same problem but mine was further inside so I had to remove the whole dang pump, arggggggg.
Rick
Mar 30, 2009 | Whirlpool 24 in. ADP6940 Dishwasher
Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG dishwasher bottom arm not spinning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
syte
Aug 24, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG LDF6810 Built-in Dishwasher Logo
125 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
