Question about Toshiba 32HFX71 32" TV
Try # 2... Green Fog
I tried entering a problem and halfway through my message the text disappeared....sorry if this gets reposted. Summary: Picture has "light green fog tint" more pronounced on dark scenes. Using yesterdays NASCAR broadcast on FOX I observed the following Grass: GREEN Red Flag Icon: RED Blue Graphics: BLUE Yellows and Oranges also appeared correct. I'm guessing that all 3 guns are functioning. I notice when watching BabyFirst TV that the logo flower has all the primary colours. The screen white is white. Black never seems black enough. In dark scenes ( inside parked cars, dark rooms for example) always appear greenish. To get the correct level of black (to my taste) The following properties are set. CONTRAST : 100 BIGHRNESS: 0 ( or a value very low... 5 - 16) SHARPNESS: Undeciided yet. COLOUR LEVEL: Varies, currently between 50 and 63 TINT: 0. Haven't explored yet. They colurs are still a bit off and dark, I know I can correct dark by increasing brightness at the risk of maing the fog situation worse. The fog I referr to acts the same as if you were to reduce your contrast... so that it starts smearing everything with grey....except it's green. TV source is mostly SAT RECEIVER via Component video. This renders SAT RECEIVER colour control inactive. Picture quality is the same via S-video connection. I can change SAT RECEIVER colour with RECEIVER controls when using S-video. Generally A green hue covers the screen while viewing dark scenes. I have the contrast cranked up so high to get a good white level and black level that I think this is why I'm seem flyback lines...diagonal lines (especially on fade to black scenes). I wish there was a DVD or some type of colour setup image so I could tume the picture and forget about my judgemental interpretation of what I'm seeing. I have not, as of yet checked the Colour balance while viewing a DVD or our Gamecube ( both which use COMPONNET VIDEO) I have yet to use the second COMPONENT VIDEO inputs set to verify it's not a input connector issue. I seem to recall the GAMECUBE exhibited the same problem, just thought it was the gamecube. I don't recall as I haven't had time to check whether the same condition appears on the VHS or DVD players. If not, it could point to a limitation of the SAT RECEIVER. If however the green tint is consistent across all sources, then I am infiact looking at a Set related problem. Thanks for the Read...
  • 2 more comments
  • Steve Johns Feb 26, 2007
    Sorry, I forgot to add it is (as the thread indicates) a Toshiba 32HFX71 televison. NTSC format (Canada).
    Thanks
  • Steve Johns Feb 27, 2007
    Update:
    I tried a DVD for a different source. Black (blank) screen was definately green.So this rules out the Mpeg4 compression of the Sat Receiver. The S-video in off the Sat Receiver exhibited the same symptoms.
  • Steve Johns Apr 13, 2007
    NOT A SOLUTION, BUT A FOLLOWUP.
    Discovered we had two weeks of warranty left on this set. The service guy came up and said "Yep I know what the problem is". When he called the next day with his quote...the picture tube. This set is only 3 1/2 years old....Jeeze.
    Turns oout the part is no longer available from Toshiba. In fact we're told that they are not making T.V.'s with CRT's anymore. So I'm left needing a new television. The service fellow made some recommendations...he said not to go over 37" with an LCD; indicated continued problems on screens larger than 37"
    Does anyone have any recommendations?
  • Anonymous Dec 02, 2007
    I have the same issue with my 32HFX71. Anytime the source material is dark (film source and/or night scenes), the screen has a green tint to it. When the source material is sufficiently bright (live source and/or daytime scenes), the problem goes away.
    Upping the brightness and contrast on the television itself does nothing. However, I have found that overdriving the brightness levels via an external device helps. Some things look a little washed out when it is too bright, but the dark green problem is much less of an issue.
Well I used to do service work for Sharp and HP so I should be able to find this. I was hoping to hear that it was an adjustment and not a failing tube or something else. TV's aren't my bag, I know how to watch 'em and that's about it. Any thoughts on what to use as a source? Some kind of calibrated picture?
Posted on Mar 04, 2007
    Novelist:
    Champion:
  • 236 Answers
The green gun in your picture tube is set a little too high. If you are experienced in removing the back cover of TV's,etc., you may try to find the drive and/or bias controls either on the circuit board that plugs on to the neck of the picture tube or mounted on the main circuit board of your TV. These controls are usually labeled. If you can find them, locate the green bias or drive control and back it down a little while watching the picture through a mirror. A slight adjustment may correct your problem.tJIS IS CALLED GRAY SCALE ADJUSTMENT. BE CAREFUL THERE ARE SOME HIGH VOLTAGE CIRCUITS NEARBY. WORK WITH ONE HAND AND USE AN INSULATED TOOL TO MAKE ADJUSTMENTS I hope this may help you.AGAIN BE CAREFUL!! Stargazer
Posted on Mar 03, 2007
When i send a text message it says its been sent but the other person doesnt get it
1.Restart your phone and try.
2.There will be some numbers in message settings (sorry,i forgot the exact name)but search in message settings and just erase 2or3 digits and enter ther same numbers and save it.
3.Contact your customer care.
Apr 19, 2016 | Cell Phones
When i try to send a text message to anyone it doesnt send and there is a green diamond before the message
Good Morning please try it:
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Dec 03, 2012 | Motorola Mobility Mb502 Blur t-mobile...
Can not enter text on Facebook on Nokia c3
are you using the pre installed FB app? i would like to suggest you use Opera mini
Mar 06, 2012 | Nokia C3 Cell Phone
I have a samsung sgh-c300 when I try to send a sms message my message disappears and a new screen appears with the meassage 'enter sms centre' my text messages are not sent. Please help
hi
there must be the message centers that not define in your mobile kindly check the message settings of your Mobile.kindly message center of your mobile. then ask your service for this problem .. they can fix it
thank you
Dec 19, 2010 | Samsung SGH-C300 Cellular Phone
I try sending a text and it says "enter center?" what is that?!
i think ur message service centre number have vanished . call to custamer care get the message service centre number and type that number in message settings then it may work. and sorry for my english
Dec 02, 2010 | Cell Phones
Nokia 6300 Some contact names dont show when receiving texts
try entering the (+) plus sign and the country code then the mobile number / editing the numbers of your contacts. such as, a mobile number alone (depending on the sim) that reads as 09178943874 must be edited as +639178943874 (noting that +63 is the country code).
Apr 26, 2009 | Nokia 6300 Cellular Phone
Voyager LG/Verizon Text Sent File Question!
I get a green arrow when I send to people.
The green arrows turns into a checkmark, when the message is delivered.
With Verizon people this is usually within a minute or so, of course unless my friend has his phone powered off - which he will do, then I don't get a checkmark until his cell gets the message.
With Non-Verizon people I don't get a green checkmark until a day later, must take longer to confirm they got it from another cell company.
The RED X is normally what I get when I try to send to a landline or an invalid phone number, or if I try to send a message - while my phone was getting an incoming message..or to someone who has text blocked. The RED X means it did not go through at all. I will re-send these if I know it's a cell phone that can get text. Then I usually make it to green arrow/then green checkmark.
Feb 22, 2009 | LG VOYAGER VX10000 Cellular Phone
Test messages
try takign otu the batery and putting it back in and waiting if that doesnt work try deleting all the text msgs on the phoen and giving it a lil memeory
Apr 12, 2008 | RIM BlackBerry Pearl 8100
Toshiba 32HFX71 32" TV Logo
196 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
