Question about Canon PIXMA MX310 All-In-One Printer
Scanner will not scan MX310 - Canon PIXMA MX310 All-In-One Printer
  • Anonymous Dec 28, 2008
    same thing
    Scholar:
  • 134 Answers
Solution: Press the ON/OFF button to power on the multifunction device
Press the ON/OFF button to power on the device. The device has an <ON/OFF> button.
  1. Connect the power cord from the device to the electrical source.
  2. Press the <ON/OFF> button.
  3. Wait until the device has completed its cycling process before submitting a job request or completing installation.
OR
Try to Uninstall and Reinstall the Driver If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them.I hope it helps!!!
Posted on Dec 09, 2008
4 Suggested Answers
SOURCE: Scan problems with Canon MX310
I had the same problem. After replacing the USB cable with a good one the scanner came back to life.
I suspect scanner has a higher requirement for USB data transmission thats why printing and copying work but scanning does not.
Posted on Sep 20, 2008
  • 9 Answers
SOURCE: cannon mx310 won't scan
Go to this link. It is Canon's Support page. It can answer this question.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
Posted on Mar 25, 2009
pheireith244
  • 310 Answers
SOURCE: canon mx310 won't scan message reads "the
Please go to Control panel and choose add or remove programme.. kindly uninstall the program i.e. Your printer driver after all re-install the driver... thanks
Posted on Aug 22, 2011
HOW TO USE SCANNER
i have found the way to scan items from a Canon MX310 (on windows)
1.On windows go to control panel
2. click hardware and sounds
3. then hit devices and printers
4. then click on the Canon Inkjet MX310 seriers
5. then you will see scanner management click on scan Photos or docs
6.then place the photo or doc under the scanner and hit scan!
That is all the steps you will need.
17 years old computer tech.
Dec 15, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 won't scan message reads "the
Aug 22, 2011 | Canon PIXMA MX310 All-In-One Printer
Trying to scan something to the pc and the printer says pc standby. I do not have any software.
If you have a Windows or Mac OS X PC, go to Canon.com and download the TWAIN (scanner) driver for the Pixma MX310 printer; and of course install it, so you can scan. Otherwise, try both FOSS scanner backends.
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
How can i fax and scan on canon mx310
for scan, in windows go to accessories
click on scanner and camera wizard
select your pixma mx310
click on next
click on preview for preview you document or photo click next
click next
now it show your scan document
enjoy
M. Zahid click next
click finish
May 14, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a Canon MX310 printer/fax/scanner and suddenly the scanner is not working. I am pushing the scan button and the icon is not appearing on my desktop at the bottom of my screen. Any thoughts?
Reinstall again the cd installer because its not completely installed.
But you can still use the scanner from your computer and not on the scan button of your printer.
Go to the Control Panel....Double click the Scanners & Cameras icon.. Double click the icon of your printer scanner.
Good luck.
Sep 18, 2010 | Canon PIXMA MX310 All-In-One Printer
I want to be able to transfer scanned documents from my canon MX310 printer/scanner to my computer so that I can save them to file
Scan directly from your computer.
How?
Click start,
select control panel,
double click Scanners/Camera
Select the model of your all-in-one and click it
put in the scanner the documents for scan.
On your computer click next
rename the scanned documents and browse for directory where you want to save it. Follow the instructions that will appear and you will not lost in the procedure
Jun 21, 2010 | Canon PIXMA MX310 All-In-One Printer
How do i use the scanner on my Canon MX310 ?
You need to control the scanner thru your PC with canon software that came with your printer/scanner otherwise you cant scan anything..
First open the printer/scanner software on PC,select scanner,then place your document and command "scan" on your PC..On this window you can also alter the scanner preferences..thats it..
Nov 13, 2009 | Canon PIXMA MX310 All-In-One Printer
How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
Mar 30, 2009 | Canon MX310 Office All-In-One Printer
Canon mx310 scanner
I know i have the same problem
This is how you get around
sorry the scan button is useless but what you can do is fing the scanner and camera wizard on your windows computer and it is selfexplanitory from there
Jan 28, 2009 | Canon PIXMA MX310 All-In-One Printer
Aug 16, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
1,441 people viewed this question
old marine
old marine
