Spin cycle I have a maytag neptune front loading washer, model # mah8700aww. On the spin cycle it sounds like a jet engine and moves freely all over the laundry room. I just recently opened up the back seeing nothing wrong or any loose parts. The shocks are intact and the drum seems fine. Am I missing something else to look at?
  • AmyCS Apr 02, 2009
    I just moved into a home that has the same machine and was horrified to find that the washer moves... and sounds like there is construction going on on the 2nd floor during the spin cycle
    did you get an answer to your question yet? I'm trying to avoid the expense of having a service call from Maytag repair.
Rear shocks tend to wear faster than the front.
Try switching the front shocks to the rear. If this helps, plan on
buying 2 new ones. You will have time to search for the cheapest price... typically 25 USD @ /www.appliancepartspros.com/
Posted on Jan 05, 2009
I have the washer too and it does the samething like a jet engin taking off. what gets me is they recalled the MAH9700AWW but wont recall the MAH6700AWW for the same reason. I wrote a report to the goverment website that handles recalls. I havent heard anything yet. but i already replaced the inner glass 2 times not gona do it again. but my washer is only 5 years old.
Posted on May 26, 2011
I have a maytag mah8700aww washer,when it goes into spin,there a loud knocking sound
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
I have a maytag neptune washer and the spin cycle is really loud is that normal. Kinda like a jet engine but it is complete level we checked?
you have described the noise from a front load washer in the spin cycle to a "T", it definately does sound like a jet engine. if it ain't broke...don't fix it!!
Oct 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
May 28, 2009 | Maytag MAH6500 Neptune Front Loading...
My Maytag Neptune fnt loader Model# MAH8700AWW Ser# 12227145GR
I have the same problem. The technician seems to think it could be the water is not emptying during cycles. It keeps adding water as the cycles continue and therefore over flowing the tube when it spin. He thinks it could be a water level sensor. Not sure at this point.
Feb 27, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
324 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
