Out of Range with HDMI cable on Bush LCD TV
I have a Bush 37TV016HD TV which has an Out of Range message when I use a HDMI cable. I have tried 1080 and 720 resolutions on both a DVD player and VirginMedia+ box and get the same result. It's fine with a scart but I cannot get anything but this message using the HDMI. I'm guessing it is a problem with the TV and wondered what I should do to get it fixed. Any help.....very grateful
  • Anonymous Mar 07, 2009
    I HAVE SAME PROBLEM WHEN MOVING PS3 FROM SAMSUNG TV DOWNSTAIRS TO ACOUSTIC SOLUTIONS TV UPSTAIRS!
    Problem Solver:
  • 10 Answers
If it is a low end cable that could be your problem. Also some players require a certain bitrate that must be transferred and lower end cables lack this. This is especially true for videogame systems.
Posted on Nov 29, 2009
My dell 32in LCD tv is showing an out of range error
sounds like your apple TV is putting out a higher resolution than your TV supports. Is the resolution on your tv 720 rather than the 1080 that the apple tv outputs. If that's the case go into the menu on the apple tv and change the output on the apple tv to 720.
Feb 02, 2014 | Dell W3201C 32 in. LCD Television
Trying to hook up to HDMI 1 (playstation 3), but keep getting message "not support" can you help
you have to change the setting on the ps3. change them to 1080p not 1080 I. or a lower number. your tv dont have the full range in HDMI.
Sep 16, 2013 | Vizio E370VL 37 in. LCD HDTV
How do I set my tv to 1080
You don't set your tv to 1080. You set whatever you are connecting to your television to 1080. Let's say it is a cable box or blu ray player. You would need to be connecting it to your television with an hdmi or component cable. Connect it only once to the television with an hdmi or component cable. This may sound ridiculous but there are people that have their devices connected to the television three times with three different types of cables (hdmi, component, composite) instead of just one. Make sure the television is on the proper input. Adjust the video output settings to reflect 1080 i or p if possible resolution.
Apr 07, 2011 | Polaroid 3211TLXB 32 in. LCD Television
Samsung LCD TV LN40A550P3F will not support 1080 format when hooked up to HDMI via Directv receiver.
Hi, is the directv box giving out 1080? There is an option on the box to select between 480, 720, 1080.
Also the tv has the same option.
Feb 12, 2011 | Samsung LN40A550 LCD TV
Connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Jan 27, 2010 | Televison & Video
HDMI connection
Change the HDMI cable, try other borrowed from a friend t make shure is not the cable
Nov 19, 2008 | Acer AL2416WD 24 in. LCD Television
Hd tv
My HDMI has stopped working. I have had a technician from Dish network out to my house 3 times and they have replaced the receiver and the HDMI cable and were unable to get the set to work all I get is a blue screen and a message which reads no signal. I also cannot use mt set using 3 rca cables connected to the component input when set to 1080 I keep intermittenly get a black screen then a blue screeen and sometimes a no signal message. I have to watch the tv set to 720 on component 2 and it is the most stable in that setting. Please send help
Jul 06, 2008 | Protron PLTV-37 37 in. LCD Television
Phillips hdtv
if the cable box is sending in 1080 signal the tv will not be able to format to a 480 (you can switch to either/or)
the problem you have is if your not sending 1080 to the tv your not really watching HD but you cant strech the 4:3 (non HD channels) to the 16:9
the only thing you can do is run analog signal and a digital signal then switch between the two sorces for your HD and non HD programs
Mar 11, 2008 | Philips 42PFL5332D 42 in. LCD Television
How do i connect my 360 to run on HDTV to a bush lcd tv?
HD is a new sort of signal transmitting/receiving technology; therefore, all software and hardware components you have to use must be able to support the relevant technology. (HDMI=High Definition Multimedia Interface)I am not sure if your 360 has an HDMI output, but if it has one, you have to use one of those HDMI cables. As well, the LCD model you mentioned has to be able to support HDMI signals. As I know, scart plugs don't usually support HDMI. Similarly, individual connector cables don't support it either. All you need to have is a digital coax cable.
Apr 16, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
971 people viewed this question
Top Televison & Video Experts
