Question about Refrigerators
The electrical transformer to our home failed and apparently sent a surge to our appliances that were running. Our frigidaire refrigerator, model GLHS68EGSBO will not cool. It appears the controls were zapped as their are lights, but no cooling. On/off button does not respond. How can I check to see if a control fuse was blown?
Kenmore coldspot can control fuse be blown? where is it for the freezer?
Posted on Dec 11, 2008
Panasonic NN-C2003S microwave is completely dead. No lights, no action. Have taken cover off and checked fuse, which looks like it is in good condition.
Would need to check power to main board. A lot of times it is the small low voltage transformer on the main board. If the primary winding goes bad it cant get power to the rest of the board to function. So to start, is there power getting to the low voltage transformer on the main board??Have you had any thunder storms or power surges at your home where it is plugged in? If a home loses its Neutral power line it can mess up a lot of electrical devices in the home. do you notice your lights browning at times. If so you may need to get your power company out to do a load test on you system. But the transformer is a very low amp device and will not blow the main fuse if it goes bad. So you could bhave aburnt trace on the back of the main board or a bad transformer. Best guess. Good luck
Jun 26, 2017 | Panasonic Microwave Ovens
Gauge reads of
Hello Erin;
My name is Peter. I am a retired field service refrigeration.
You need to have individual surge protector on all of your appliances with a control board. They are $15.00 - $20.00 at Lowes or Home Depot. They will one day save you an expensive repair bill. Power surges and even static electricity will knock out a board.
Now, in your case I do not believe you have a power board problem.
I can not help you unless you send me the model number. The model number is on the inside wall, near the top in your fresh food section.
Dec 13, 2014 | Frigidaire Refrigerators
Why would my Frigidaire refrigerator stop working when I turned my electricity off and never come back on
Hello;
My name is Peter. I am a retired field service refrigeration technician.
It is recommended by manufacturers that appliance, especially those the control boards have surge protectors.
Try rebooting your unit. Unplug you unit for ten minutes. Then plug it back in. If it does not start, you blew your main control board.
Oct 31, 2014 | Refrigerators
Frigidaire does not cool and sometimes shocks you
Good morning friend, thank you for your post!
I understand that your Frigidaire refrigerator is not cooling and will shock you. I would recommend you having a technician come out to your home to properly diagnose and repair your appliance. Normally if it is not cooling we could provide some troubleshooting but with you appliance discharging electric energy I would recommend service. I hope this is helpful. -Matt
Aug 09, 2014 | Frigidaire Refrigerators
Frigidaire refrigerator is beeping, it is working great, just 8 months old
Good Morning Friend,
I see that you are having trouble with your Frigidaire refrigerator, model# FFHS2313LS, beeping. There could have been a possible power failure. In the event of a power failure, the 'power fail' alarm will sound three times. The 'power fail' alarm is an audible alarm only and does not display in the control panel. I suggest resetting your appliance, by either unplugging it, or shutting the power off at your homes circuit breaker, for 2-3 minutes. When you bring power back you will hear the 'power fail' alarm again. If you notice your refrigerator still beeping, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine why it is beeping. Hope this is helpful.
-Best Regards-
WP
May 11, 2014 | Frigidaire Ffhs2313Ls 23 Cu Ft Side By...
After a lightning storm my bosch single 30" wall oven displayed an F03 err. I turned the power supply off at the breaker for one minute as directed by the oven's manual. This action did not...
Find out what the F03 error is for and then check out the appropriate area. If there was a strike of surge the most likely place to look for damage is the area where the electricity first enters into the device.
Sep 07, 2017 | Bosch HBL 5036 Electric Single Oven
Power in house went out for 6 hours now the coil is cooling but fan not running
Your defost timer control board may have burned out from the power surge.I think they are electronic defrost on there models.If not you may need a compressor relay kit.Yuo can get the parts using your model # at your local appliance parts store.
May 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Had electrical prob. blew some breakers for kitchen circuit. After fix all other affected appliances/outlets etc. are fine but KitchenAid dw now does not work. No sign of life at all, no led's light on...
Hi and welcome to FixYa. I am Kelly.
With electronic controlled appliances today and in this case your dishwasher. The printed circuit board (PCB) transformers are very susceptible to power surges. The windings are just large enough for the normal operational voltages. Anything above or below that range causes the windings to fail rapidly. When they fail you do not get the 5V or 3.3 V for the LEDs ' and IC chips or the 12V for the controlling the relays for normal operation.
I don't see a model number listed for your dishwasher so I can not provide the replacement part information at this time.
Before I went into the parts changing mode I would first go back and reset every breaker in the house by:
1. Pushing each breaker with conviction to the OFF position. This completely resets the breaker.
2. As you turn each of the breaker ON push hard on the face of the breaker near the center of the main panel to ensure it remains connected / engaged to the main power buss bar.
Then go back and check the dishwasher for signs of life. If it works great! If not.... I will be watching for model number information if you need help with the dishwasher control parts information.
Just a side note... you may want to check your home owners insurance coverage (if your a home owner) to see if it covers repair of equipment other than the one that caused the original problem.
Thanks for using FixYa.
Kelly
Mar 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Model ATF6000751. Replaced speed control board a month ago when final spin failed. Worked fine until yesterday. Could something else be causing the board to go bad?
Power Surges. In my area we suspect that 70 to 80% of the repairs here are caused by power surges. They happen all the time, andyou do not have to lose power to have one. They can happen when you have lightning, windstorms or beutiful sunny days. You have to have a 2000 joule surge protector or higher on your washer, refer, microwave oven, and gas stove or dryer if you have them. For your washer , gas dryer, and refer you have to have a rectangular box wall mount surge protector. You cannot have a power strip surge protector on a cord as moisture can get into it and cause electrical fires. I have seen three major fires caused by power strips behind washers. Lowes and Best Buy sell wall mounted box surge protectors with a 2150 joule rating that have 3 plugs on each side that rotate from front to the side so that you can plug your refrigerator into the side and not have the refer sit out from the wall any more. Good Luck, Appliance Specialists.
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
All TV's in house failing, a few at a time
Hey PNorris,
If multiple electronic devices are failing in your home all at once, I would probably first have to ask if your home recently experienced an electrical storm or major power surge of any kind.
Normally the effects of such large-scale surges are immediately noticeable - TV's and other major electronic devices may fail to turn on, fuses may be blown or circuit breakers tripped, and in some cases electrical wiring may be melted.
If nothing like this has happened recently, low-level power surges may still be a potential cause of this problem. When the motor from any large appliance (such as an air conditioner or refrigerator) turns on or off, it often diverts power to and from other electronic devices using the same circuits. This fluctuation in electrical current may result in low-level power surges to every connected device. While not immediately noticeable, these low-level surges can often cause the eventual failure of (and gradually degrading quality in) many audio/video components.
Typically, the easiest way to avoid situations like this is to make sure that outlets are not overloaded and surge protectors are used with every major electrical device in your home. For older homes however, replacing the house's wiring may be necessary. Homes that were originally built at the turn of the 20th century may not always have wiring capable of supporting the electrical needs of many modern appliances.
Ultimately, this means that in addition to contacting your local TV repair facility, you may want to also speak with an electrician. This is probably the best way to determine whether or not power surges have caused these failures, and may give you a better idea how to proceed.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
