Question about GoVideo R6750 DVD Recorder
Machine will not read disc - GoVideo R6750 DVD Recorder
  • stephanieali Jan 04, 2009
    I have inserted several new DVD+R's with no luck in the recorder reading them.
  • GoVideo Master
  • 19,396 Answers
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Posted on Apr 27, 2009
Why does the disc reader say "no disc" after I put one in? It played earlier
Not all disc are equal.
Try a different disc. Some machines can be fussy about certain discs. Sometimes the disc itself can be kerfluewy, so try the disc in a different machine, too.
Mar 24, 2015 | Televison & Video
Dvd player reads "no disc" when I put disc in
Are the discs copy's or originals if there copy's some systems will not read them, if there originals then clean disc on laser eye with a cleaner disc
Mar 07, 2014 | Sony BDP-S350 Blu-ray Disc / DVD Player,...
Kmx02 disk spins fast, does not read
Educated guess is the deck cannot read the disc for some reason and is trying to find the index to start reading it. Try another disc and see if you have the same problem. Some discs will not play on some machines especially if you copied them yourself due to data duplicating copy guards installed in some machines.
Mar 04, 2014 | Numark Industries Numark KMX02 Dual Deck...
On my Husqvarna Viking sewing & embroidery machine...when I put in a floppy disc I get the error message: General disc error. What is wrong?
It can't read your disc, it may be damaged or needs to be cleaned. It could also be the wrong disc for the machine. The machine can't recognize it.
Jan 24, 2014 | Husqvarna Sewing Machines
I have a teac MD-H300 minidisc player that doesn't read discs
That's an old machine from 2001. Buy a working machine on eBay or Craigslist.
Mar 21, 2013 | Audio Players & Recorders
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
Will not read dvd disc
This can be due to dust in the machine, on the disc or surdace damage to the disc.
These are the most common causes anyway.
Clean the disc itself with plain water and wipe with a soft cloth gently to dry it.
Run a CD Cleaner disc in the machine for 30 seconds, and dust off the loading tray/area with a soft brush.
Then try again.
Try other discs to see if the machine is ok - or whether it is the new disc that is faulty.
Smetimes you have to load the disc 3 or more times untill it reads a certain bit of data correctly to start, after this it doesn't seem so important.
Sep 14, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Disc not reading on wii machine
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 26, 2008 | Nintendo Wii Console
Disc Not reading
mine is doing somthing like that too. but i don't get beeps or the A4 symbol. stacy_sunshine_t@yahoo.com if anyone can help.
Sep 17, 2007 | Panasonic DMRES15 DVD Recorder
GoVideo R6750 DVD Recorder Logo
105 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
