Question about ASUS P4P800 SE (890552603657) Motherboard
Upgrade from P4 2.4GHz to P4 3.0GHz Prescott on P4P800
Doesn't boot, doesn't heat-up, no sounds, black screen, new 500W PSU. Putting old chip back always restores it to running condition.
  • kris866 Dec 09, 2008
    I RMA-ed it and second chip behaved the same way. That's when I upgraded PSU from 300W to 500W but still no change.
    I'll try to play with CMOS, but that's a pain since I have revert to old chip every time I want to change CMOS settings.
Playing with CMOS settings didn't do anything. I downloaded BIOS upgrade, although it was a Beta version, from the ASUS site and that seemed to resolve the problem, however only temporarily. Initially I overckloced it by 30% and it seemed to be happy. But, since my USB-TV stick didn't produce the right results (lots of clicking noises, picture jumpy, etc) I decided to bring it back to standard speed and that's when things started going bad and in a minute or two the screen went black.... motherboard was gone!
At this point my solution was to get new MOBO, new CPU (AMD), memory and SATA HD-in other words a new computer. It set me back by $325 but I have a Tripple core (if I remember the proper name for it) CPU, audio and video on board (I am not a gamer!?!!??), my TV stick works great and I'm happy. Here you have the full story.
Posted on Jan 06, 2009
    Scholar:
  • 99 Answers
Sounds like the new CPU is bad. The only other thing that it could be is if there are some settings changed in CMOS. I would clear the CMOS and if that does not fix it then the new CPU would be bad.
Posted on Dec 09, 2008
Best cpu upgrade for HP pavilion MS214 AIO PC
This sounds like a good idea, I would go for the upgrade, since I don't and very rarely have had an AMD system, I'm not 100% sure on which chips are compatible, as for the wattages, that's the thermal design power (TDP) or heat output so the PSU won't need to be changed out, heck, I have a 192.1W psu on a system that needs a 300W PSU, my CPU TDP is 110W, no issues there apart from energy efficiency of the PSU under full load!, your PSU should be fine, they're normally rated higher than the system needs under a load to improve efficiency, the load is best optimized at 50% but the PSU on your system under an intense load should be around 60% with the new chip which is pretty good if you ask me :)
in other words, go for the upgrade, get a chip that works from Amazon or EBay for a low price, then, if it isn't compatible, it won't be much of a a big loss... anyway, there's always overclocking, just get a more powerful cooler and crank that clock speed up, the chip should handle up to 2.08GHZ which is a really good overclock for a chip like that!, remember to stress test the system for at least 24 hors on an overclock with Prime95 (from Mersenne Prime search)
Good luck :)
Jun 24, 2013 | HP Pavilion AllinOne MS214 185" Desktop PC...
My ati radeon 5450 when i am putting it in my computer my PC won't boot,... it shows power but will restart automatically,.. i have 500w morrLogic power supply,.. i also tried my old gt 7300 ddr-2,.....
Many flavors of this video card from various manufacturers have different configurations - most important is the auxiliary power connector that appears on the edge of many of these cards. If your ATI has such a connector, it must be connected to the PSU. The MoBo bus can not supply the required power via traces on the board. If connected and it doesn't work - it may be a power supply problem.
While your 500 Watt power supply unit (PSU) is more than the 400 Watt minimum requirement, but depending on its efficiency and your system configuration, may still be on the "weak" side. Your particular PSU is not a certified type. ATI recommends using certified PSU's on this list. You could probably get away without using one of those expensive PSU if you got one with a little more "umpph" to it, say a 600 watt or more rated type. The 500 watts unit you currently have may be "just a little too close" with your PC's configuration.
I hope this helps & good luck!
Sep 13, 2011 | Computers & Internet
I have a an Asus P4P800 Motherboard and when I boot up it is giving two short beeps, displays the motherboard screen, goes black, and then does the sequence starting with the two beeps again and...
first make sure the RAM is securely seated
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 17, 2011 | ASUS P4P800-MX Motherboard
What PSU will work with my Acer T690?
Any new ATX PSU will do.
Prices variate, but an 500W PSU is good for this purpose and medium in budget terms.
Feb 20, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Memory Upgrade
Not knowing what model of computer you are talking about, I'd suggest you try various combination's with your memory modules as some computers are picky and accept certain size memory chips in certain slots only.
Furthermore, it could be there is a bad connection on the sockets or if you have not been ESD safe, you could have zapped the memory chips and or the main board.
Jan 10, 2009 | Computers & Internet
Not Booting
Hi, This is an old board trying to run a hungry CPU. From the symptom you describe the poor thing may be wearing out right in front of you. Anyhow, - In order of likelihood your problem(s) are probably:
1 - Defective motherboard. PC chips is well known as a maker of cheap mobos. When run even a little hot they have a short lifespan. A 3Ghz Pentium Prescott needs a lot of power. A faulty part may not always kill a session but it can ruin your life. Try running the PC underclocked at ~2Ghz. See if the prob goes away. If so, better cooling the support chips may help. Best solution is replace this old warrior with a new mobo. You will also need a new PSU & CPU if this is the problem. Except for playing games, even slow dual core CPUs will perform better than a single core unit.
2 - Bad PSU. These also wear out, especially if run hot. Best solution is new PSU. If you do this, get a modern model that will handle a mobo upgrade should that also become necessary. Many options & prices here - be careful.
3 - Bad PCI card or RAM. If you already haven't - try removing all unnecessary hardware... then test for problem. Switch your DDR2 RAM in & out to test for defect.
4 - Bad CPU. Not likely but possible. try running the PC underclocked at ~2Ghz(if this mobo lets you). See if the prob goes away. If so, better cooling might be the hot tip
Dec 15, 2008 | Intel D915GVWB Motherboard
648FX-A Motherboard doesn't seem to work with P4 3.0Ghz
looking up the motherboard online shows that it supports the 3.0Ghz processors but only the nothwood ones, not the prescott ones. and only up to 800Mhz side bus.
suport page:
http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=323&MenuID=69&LanID=0
Hope this helps, sorry if your cpu is a prescott, if it is a northwood RMA it for a new one.
May 10, 2008 | EliteGroup 648FX-A Motherboard
New P4 3.0E wont work in P4s800
check your proccessors motherboard support.
May 09, 2008 | ASUS P4S800 Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
120 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
