Question about Akai PT4298HD Rear Projection Television
AKAI MODEL#PT4298HDX/SMS RED TIMER LIGHT JUST KEEPS BLINKING
WHEN I TURN MY TV ON THE TIMER LIGHT JUST STARTS BLINKING WERE CAN I GET THE PARTS TO FIX IT AND WITCH BORRD IS IT
  • 3 more comments
  • Anonymous Dec 31, 2008
    WHEN I TURN MY TV ON THE TIMER LIGHT JUST STARTS BLINKING WERE CAN I GET THE PARTS TO FIX IT.
  • jalosolo Dec 31, 2008
  • Anonymous Jan 03, 2009
    aa41-00600e
  • jason_philli Jan 05, 2009
    akai tv model 4298hdx/sms the red timer light comes on but there is no picture or sound does any one know what the problem is and how it can be fixed
  • Shannon Burgess
    Shannon Burgess Jan 28, 2009
    thanks
  • 20 Answers
Do not panic! Do not throw your TV away like I wanted to! Here is whatmay be the solution for most of the members who have posted theircomplaints here recently. I am not an expert, but I followed all blogsfrom various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it fromwww.partstore.com and since this Akai is the same model as the SamsungModel # HCN4226WX/XAA, buy the Samsung BP95-00142E Convergence boardfor $77. It came to about $85 after shipping. The Convergence board hastwo black STK ICs and two colors of wires, a gray kind and a bluekind, all which have 'pins' and can easily be unplugged from thecircuit board in the TV. It is basically a complete system that takesless than 30 minutes to install. It is a simple swap procedure, with nosoldering. You only need the new board and a screwdriver! Remove thelower back board of your TV where the cables are plugged in (do notunscrew all the screws for the screen, as it is unnecessary, and mightjust damage your screen if you are not careful.) It has a u-like shapeand comes off easy. Detach the gray wires connecting your old board tothe rest of the circuitry, and detach the blue wires connecting the oldboard to the circuitry. On the old board, there are connectors marked,from left, blue, green and red. Detach those from the old board, andmark the wires so that you may connect the correct the wires to the newboard. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks whichheld the old board, and screw the lone screw to the board. Plug thegray cables from the new board to the connectors where the gray cablesfrom the old board were,and do so for the blue cables. Connect themulticolored cables to the blue, green and red, just as was done on theold board. Reattach the cover and test the TV. Please do not replacethe two STK ICs only. When I removed my old board, I realized thatthere was a burn mark, where the ICs were, but maybe it was a fuse. Youmay replace the ICs only to discover that it was another problem. Goodluck, and I wish you all the best in the repairs. I just saved about$100 for a repairman just to show up
Posted on Dec 11, 2008
AKAI PT5598HD will not turn on.
if you got to the following link and search by the model number you will find what your looking for.
Http://www.samsungparts.com/search/search.asp
The part number for the service manual is SM-PT5598HD
As the set is showing a blinking red timer light. you can check the following link out.
http://www.techlore.com/article/15444/
May 13, 2008 | Akai PT5598HD 55" Rear Projection...
R tv akai pt4298hdxj/smsmanual
Check for bad connections on your yoke plugs. Each pic tube has its own yoke and will go to the main pc board, It will be a 4 wire plug w red, blue, etc. Two for vertical two for horizontal.
Nov 11, 2011 | Televison & Video
We ahve an Akai Projection TV PN# PT4298HDX/SMS TV turns on but no picture
Sounds like your bulb went out, I would call the manufacture or a local TV repair shop to find the part.
Akai Corporate: 323-281-0782
Aug 27, 2011 | Akai Televison & Video
Akai, pt4298hdx-sms 2003, it has two colors and in waves
the convergance ic's have failed they are stk392-110 you will need 2 and they run around 24 to 25 bucks a piece you can get the complet convergance board for around 75 dollars on that set it is located up mounted to the crt bracket try partsearch.com of shopjimmy.com
Dec 11, 2009 | Televison & Video
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
An Akai PT 4298HDX/SMS with a blinking red light
it jus depends on your electronic back ground and if you have multimeter and solder equipment. or a little easier ifnyou can confirm it is the power/deflection cba it is sold as an entire assemble in this model that does not require solder work to change. big board on the right looking at from rear with large black transformer on it with red wire coming from top. a company called vance baldwin sells these parts
Jan 22, 2008 | Samsung HCM4215W 42" Rear Projection...
Akai LCT2716 Flat Panel TV
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Sep 13, 2007 | Akai LCT2716 27 in. LCD Television
Akai PT4298HD Rear Projection Television Logo
1,574 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
