Question about JVC FS-5000 CD Shelf System
Cd player does not work
Am/fm radio works. When I put in a cd and press play, the cd spins for 2-3 seconds and than stops. Is it worth getting this fixed?
  • Anonymous Feb 09, 2009
    radio is fine. cd player aux wont.
    President:
  • 2,992 Answers
The CD spins while the laser tries to focus on the disc, and that's how it knows a CD is in. It's not detecting the disc and so the CD stops. This could be simply dirt on the laser lens, and you could try using a cotton swab to gently wipe it off. If that doesn't take care of it, the laser assembly needs to be replaced. This unit cost about $200 or more if I recall, so it might be worth getting a repair estimate. If this were a typical cheap boombox it would be better to replace it.
Posted on Dec 09, 2008
I cannot get the CD player to eject the CD. the radio is a standard AM/FM radio with a CD player in a 2005 Ford explorer XLT. after pushing the eject button the radio screen blinks ''EJ err''. The cd...
Turn the radio off first and then disconnect the battery for 2 min then reconnect the battery. This should reset your radio and then you can eject your CD, and reset your stations and clock. Good luck
Sep 30, 2009 | 2005 Ford Explorer
Unlock code please for a 2006 GMC Canyon 6 disk cd player
Try this it should work for you.
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed.
2. Write the numbers down.
3. Press the AM/FM button, write down the next 3 numbers.
4. Call 1-800-537-5140, when asked, enter 620529, press the # button and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM/FM button, SEC should be displayed, turn on radio.
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Jun 04, 2009 | Car Audio & Video
JVC car stereo won't play cd
If it does it with any cd and it played before you have to clean the lense or laser. Get a cd player laser cleaner disk or cd. If you still have problems take the radio fuse off in the fuse block to restart it. Remove the fuse wait five minutes then reinstall. Also some times when you burn CDs in the wrong format the cd player will not recognize them.
May 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
CD player acknowledge CD, starts to play, then stops
I belevie you have problem in laser assembly it might not worth to repair it
Cheers
Dec 10, 2008 | Audio Players & Recorders
Aiwa CSD TD310- manufactured 2001 - looks like this(above)1)Problem getting cd to work; 2)need help with "sleep" button:how to set
Well, for the CSD-ED27 the sleep works like this:
1. press STOP/MEMORY and then also
2. press PREPEAT/FM MODE/OSC
3. your display will show 10
4. use the tuner - & + to good from OFF-90 mins
As to you CD player not playing:
it is sounds like the spinner might be not spin completely flat to the optical reader. This happen with my portable CD player, however at this time I do not have a fix for you. Good luck though.
Mar 20, 2008 | Aiwa CSD-ED27 Boombox
Cd player not working
first try play Lens Cleaner CD, if you are lucky ,it's done!!
Sep 07, 2007 | Aiwa CSD-ED27 Boombox
Jensen vm9311 AM/FM/CD/DVD
you are mising to power on the factory amp.
Apr 25, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
JVC FS-5000 CD Shelf System Logo
236 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
