Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Blower does not turn on bottom squirrl cage carrier weathermaker ignitor works pilot starts flame comes top fan starts - runs for 3 minutes then bottom squirrl cage does not start up. fuse on board good? do i need to replace motor?
  • 306 Answers
Sounds like it to me. You might be able to switch the motor speeds by taking the red wire off the heat spot on the board and taking the one that is on the park and switching them. But more then likely the blower is bad replace the capacitor at the same time.
You could take the black wire and switching with red or what ever color is on the heat spot. The black wire is on the cool spot so just switch those two. ken
Posted on Dec 11, 2008
  • Ken Bledsoe Dec 17, 2008
    Did you get your fan working? ken
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Hello, I have an achiever 90 plus ruud, when I turn it on the flame ignites but after 3 seconds it goes out, it does this 3 times than turns off. Help?
Are you saying that main burner is coming on or pilot /hot surface ignitor or spark ignitor ? If your induced draft motor is coming on then a few seconds later your main burner is coming on for 3 seconds and then shutting off but blower motor is not coming on I would look at flame sensor to make sure it is telling the fan motor to come on. Normally they will try three or four times and then lock out. One easy way to check blower motor is to set your thermostat to fan on. Fan motor should come on and run till you shut it off.hope this help you.
Nov 05, 2010 | Heating & Cooling
CARRIER WEATHERMAKER 8000.NOT SURE HOW OLD. HAVE POWER,FAN COMES ON,IGNITOR GLOWS,GAS VALVE OPENS,BLOWER RUNS,IGNITOR GOES OUT. CYCLES THREE TIMES LOCKS OUT. ANY IDEAS?
sounds like the roll out switch may be sensing a clog. here is a website that can explain things better, hope it helps Tim:
http://arnoldservice.com/Troubleshooting_Heating_Problems.htm
Oct 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Weathermaker 8000 furnance flashing code 31 blower comes on for 90 sec .. then shuts off .. then other fan goes on.. don't see any flames or lighting goin on can you help?
31 PRESSURE SWITCH DID NOT CLOSE OR REOPENED - If open longer than five minutes,
inducer shuts off for 15 minutes before retry. Check for: - Excessive wind
- Proper vent sizing - Defective inducer motor
- Low inducer voltage (115VAC) - Defective pressure switch
- Inadequate combustion air supply - Disconnected or obstructed pressure tubing
- Low inlet gas pressure (if LGPS used) - Restricted vent
If it opens during blower on-delay period, blower will come on for the selected blower
off-delay.
33 LIMIT CIRCUIT FAULT - Indicates
Nov 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace pilot is on, pilot ignitor continues to click, no main flame
sounds like the sensing bar on the spark ignition is dirty.....a wire brush works nicely.
Oct 17, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker gas 8000 will not ignite
Your hot surface igniter may be bad. It may be cracked which would prevent it from starting the burner flame.
May 21, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
91 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
