Question about D-Link DFL-800 Firewall
Dear User, If you are behind a firewall or within a company local area network (LAN), you will need to open outgoing TCP connections to Port 51215 on your proxy server.
  • Anonymous Mar 12, 2009
  • 468 Answers
OpenPort 51215 on firewall
Posted on Aug 13, 2009
    Brigadier General:
  • 10,406 Answers
Thanks for the information.
Posted on Aug 22, 2010
2 Suggested Answers
rcw1962
  • 2571 Answers
SOURCE: firewall
Posted on Jul 31, 2010
How can I download purchased items on itunes (error 8003) from behind a Cisco RV220w firewall?
Configure the Cisco to "log everything", and then try the iTunes download. Then, examine the log-files, to see which connections were blocked. Then, configure the firewall to "allow" those TCP-ports.
Apr 23, 2014 | Cisco RV220W RV220W-A-K9-NA Wireless...
Firewall
Jul 31, 2010 | D-Link DFL-800 Firewall
No network connection for windows xp
Hello kenji, hi, it would really help if you could add more information about the no connection problem, anyway there are several reason why you have no connection;
  1. Bad Lan card, or built in lan port,
  2. Lan card device driver not properly installed, check your driver CD.
  3. loose lan cable. check using a lan cable tester device.
  4. bad router or router setup.
  5. bad dsl or modem setup.
  6. bad telephone connection. check also telephone cable.
  7. no internet service, call your ISP.
  8. if you are using a wireless lan card, check the device.
  9. bad Operating system installation.
  10. check your connectivity setup, is it enabled?
Go through each from one to ten, see which one is the fault.
Jan 14, 2010 | Acer Computers & Internet
How do you open TCP port 63222?
Opening TCP ports in Windows may be necessary for getting certain applications to run correctly. Each application may require a specific port to operate on. While your computer can and does open ports on its own, in certain situations you may need to do this manually. Here are some tips.
Step 1. Launch Windows and click Start, then My Network Places. A new window should pop up. Select Network Tasks and then click View Network Connections
Step 2. Select the connection you use for the internet. If you do not know the connection which accesses the internet, you can disable each connection one at a time and then use your browser to see if your internet connectionmag-glass_10x10.gif works. Once you find the connection that accesses the internet, right click on it and select properties.
Step 3. A new window should pop up. Select the Advanced Tab and then select Settings.
Step 4. Right-click the connection that you use for the Internet, and then click Properties. Click the Advanced tab, and then click Settings.
Important Note: If your Settings button is unavailable, this means that all ports are open. Since all ports are open, you do not have to go any further to open ports manually- your job is complete.
Step 5 Click on Add to open a new port - you will see several fields. Fill in information for the following fields. For the description box and the name or IP address boxes add the details of the computer hosting the service. For IP Address you can use the following: 127.0.0.1. For the field External port and Internal port boxes, input again the IP address 127.0.0.1.
Step 6. Click TCP and then select OK. You have manually opened a TCP port on Windows.
Sep 18, 2009 | Dell Inspiron 6400 Notebook
On my echolink progtam it says to use port 5198 or 5199, how do I do it?
access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
For belkin router http://192.168.15.1
type user nams as "admin" and password as "admin" or blank or "password"
Then go to NAT and prot forwarding .
Select your port and open TCP and UDP protocol.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
then go to NAT
Aug 31, 2009 | Computers & Internet
Urgent
hi,
As per your description,in your d link firewall outgoing 51215 port is not opened.go to the access-list or security policy or access rule (I am not sure about the name) tab.make a entry like
to:the sms site ip.
service:51215
action:accept.
Regards,
Mani.S
Mar 10, 2009 | D-Link DFL-800 Firewall
No incoming and outgoing call
You may be behind a firewall or NAT. You can set an option that you are; if that still does not work, you may need to open some ports on the firewall.
Yahoo! Messenger uses a variety of ports.
Service Ports Chat & Messenger TCP Port 5050: Client Access only Insider/Room Lists TCP Port 80: Client Access only File Transfer TCP Port 80: Server Access.
Your ISP may block this port, as its used for web hosting.
You can change port in Messenger, Preferences, File Transfer. Voice Chat UDP 5000-5010
TCP 5000-5001: Client Access
If UDP Fails, TCP will be used instead, see below. WebCam TCP Port 5100: Client Access Super Webcam TCP Port 5100: Server Access P2P Instant Messages TCP Port 5101: Server Access
PMs between Buddys may not use the Yahoo! Server, but this is not a requirement.
Feb 03, 2009 | Yahoo Messenger
How to open outgoing tcp connection...... i'm facing errors in sending sms to mobile while connecting from internet........... the details are as follows Log Out...Could not Connect... Dear User, If you...
Follow these steps:
Start-> Run-> cmd
In the black box type: ipconfig [enter]
You should see some numbers like this:
192.168.*.* IP
255.255.255.0 Sub
192.168.*.* Gateway
Go to an Internet Browser and plug in your Gateway address like this:
http://192.168.1.1
or
http://192.168.0.1
Now your username and password will be like:
admin:admin
admin:1234
admin: {no password}
{nouser}:admin
{nouser}:1234
You get the drift.
Once you are in you can manipulate the firewall and port forwarding settings...
Nov 12, 2008 | D-Link DFL-800 Firewall
Problem in proxy settings
Oct 27, 2008 | Computers & Internet
Port forwading
http://portforward.com/
this site may be of some assistance
Jun 19, 2008 | Computers & Internet
D-Link DFL-800 Firewall Logo
661 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
