Question about Gateway 310S (2900621) PC Desktop
How to connect two hard disks
Hi
(1st hard disk Seagate, 2nd hard disk old model which we can connect through bus(40 pin) i.e ..)
i had two hard disks.In 1st hard disk i have installed windows Xp and RHEL 5( linux ).
In 2nd hard disk i have installed Fedora.
Now i want to connect two hard disks.I have configured as master and slave.But problem here is......
i want to show 3 o.s at boot time
But here i can able to find 1st hard disk o.s only ( xp,rhel).
Here i can not see 3rd o.s fedors.
Next time
I have entered 3rd o.s entry in boot.ini file also.As provided to that name is appering.but i couldn't boot into 3rd o.s which i have installed on 2nd hard disk.
If anybody solve my problem....(any of u having knowledge  on linux also)
One more doubt Regarding master and slave config for both hard disk...
  • Anonymous Jan 31, 2009
    have the same Problem
Japanese Pantyhose Foot **** & Asian Footjob Nylon DVD http://www.avleg.com
Posted on Apr 01, 2009
  • 449 Answers
The jumper pins for the master and slave diagram is already printed on the abck of the hard drives, just follow the direction and you are done
Posted on Dec 09, 2008
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I have a Seagate 800GB extenal USB hard drive. The port on this hard drive, to which the USB data cable connects, is damaged. Are there any vendors who can repair this port? If not, are there any other...
You can purchase an "empty" disk-drive enclosure, and then "transplant" your current disk-drive into the new case. That should recover 100% of your data.
Take the old enclosure to the computer-store, so that they can sell you a "compatible" new enclosure.
Probably $20 to $40.
Feb 22, 2011 | Seagate (ST9402113A) 40 GB ATA-100 Hard...
I want to trasfer the data from old hard disk to pen drivesI have installed a new hard disk in the existing system. Afraid the old hard disk may have virus
you must have anti virus protection for your PC and updated before you plug the old drive..
if you plug the old drive do not open any folder..scan with your anti virus defore you transfer any data...
May 24, 2010 | Seagate (9W2041-337) 40 GB Hard Drive
I am adding a seagate 320 g drive to my dell 4300 dimentions.. i have one ribbon.. with black(end socket) and grey(middle socket).. i have a maxtor already installed..the jumper was set to master on slave...
First of all make sure that your maxtor drive is jumpered for cable select and connected to black connector. Make sure Seagate drive is also configured for cable select and then connect to grey connector. If the Seagate drive is brand new you will need to initialise and partition the disk once recognised by Windows
Jun 08, 2009 | Maxtor Hard Drive
Adding a 320g seagate drive to my dell pc
The ribbon-cable to the first hard-drive probably has one connector at each end, and one more connector in the "middle". Look very closely at both hard-drives. Between where the ribbon-cable connects and where the 4-wire power connects is a set of pins. Look for 'MA' or 'CS' or 'SL' annotations above/below each pair of pins. Remove the small jumper from each disk-drive, and put the jumper back into the 'CS' position on each drive. Make sure that the "first" hard-drive is *NOT* connected to the "middle" connector on the ribbon-cable -- connect it *ONLY* to the "end" connector. Restart your computer, and watch the first start-up screen -- it should report that *BOTH* disk-drives have been detected. When Windows starts, open "My Computer" -- both disk-drives should be listed.
Hard drive problem
It's possible that your computer's motherboard is "old", and it only supports a maximum of 32GB per disk-drive.
Buy a new 80GB or 160GB disk-drive, and copy all your files from the "old" disk to the "new" disk.
Apr 06, 2009 | HP HRD DRV-SEAGATE SAS 72GB 15K 2.5 SINGLE...
Hard disk drive in slave position
Check your jumper settings... Following link is for your hard disk ST3160021A instructions.
http://www.seagate.com/images/support/en/us/cuda_sata_block.gif
Good Luck :)
Feb 21, 2009 | ASUS P5GD1-VM Motherboard
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
Hard disk not working
Hello Bshannon, An external hard disk is composed of several parts. 1 the actual hard disk drive (HDD) 2 the buffer and USB interface 3 the power circuitry that must provide a +5 and a +12 Volts tensions. If the hard disk powers on is spinning and the light are on we could exclude the 3th option. There is a problem with either 1st or the 2nd options. Most probably 2nd. It may happened due to a power spike that burned out a buffer memory. It happens pretty often with these hard disk's or at least I've seen it often. However there could be other reasons for this and some of them pretty simple. Maybe a faulty connection with the internal components, USB jacks (the one on the hardisk) is the main suspect. Yes they fail just like that, the removal or a simply faulty contact on even one of the USB's 4 signal pins will result in not having the device detected. In any case I would recomand to have it checked at a service center because these small hard-disk are sensible to electro-static discharges and power spikes and you may cause some of that to them when you try a DiY check-up. If it can be fixed it woun't be expensive, if it can't (burned out buffer memory) .. no one will be able to fix it. However they could extract the actual hdd part from it, you could use it with a laptop (they use the same type of hdd's) or sell it. If you need more directions or have any other questions please reply. Good luck.
Apr 03, 2007 | Ultra G-Technology G-Drive mini - 60GB...
Gateway 310S (2900621) PC Desktop Logo
978 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
