Question about Amana ABB2227DE Bottom Freezer Refrigerator
Noisy Amana ABB2227DEB
I purchased this refrigerator in 4/2006. By 10/2006, the unit had become so noisy that we couldn't tolerate it any longer. Scheduled a service call, and the repairman did me a "favor", and replaced a small motor that he said opened a small passage that connects the upper/lower compartments. While he claimed it was functioning correctly, it was just noisy. The motor replaced was located in the top center (behind the light). What is causing this noise, if the unit is working correctly? Is there some preventive maintenance that I can perform that would avoid this problem from re-occurring?
  • 237 Answers
The motor is an "auto damper" that opens/closes to let cold air from the freezer comp. into the refer comp. depending on the temp. There is nothing you can do for maintenance, the little motor runs the damper when needed automatically. Some motors are quiet, some are noisy (grind grind grind) as the open and close. Sort of the nature of the beast, if you're lucky you get one that stays quiet.
Posted on Feb 27, 2007
  • Michael Freeman Oct 29, 2012
    Actually the motor on itself is VERY quiet, I've noticed. The mediocre design of the damper assembly resonates and amplifies the inaudible to loud noise.
Amana refrigerator TR25S5W - noisy, running too much
Remove the lower access panel on the back of the unit and clean the coils.
Nov 19, 2012 | Refrigerators
Tip
Noisy Tire Solution
2005 Mercury Mariner noisy tires solution. Take tires off rim and turn inside out. My dealer recommended this and 50% of the noise went away immediately with more expected in the next 1,000 miles. This was my second set of tires with only approximately 30,000 miles and noise I could no longer tolerate. Hope this tip helps someone else.
on Apr 15, 2012 | 2005 Mercury Mariner
New compressor started knocking 1 month after installation
could be a bad unit from day 1,motor loose internally,or it can be moisture in the sealed system
May 12, 2012 | Amana ABL2222FES Stainless Steel Bottom...
My Amana bottom freezer model # BB20VSE, serial # 0006289684, mfg # P1321301WS has become increasingly noisy when the compressor(?) turns on. This started over a year ago and now is extremely loud. Thank...
Ah this is an indication that your condenser has become dirty, or blocked, or the fan motor is not working or the air flow is restricted.
The noise is generated when the compressor cycles off and sudders to a stop
Mar 24, 2011 | Amana ARB9058CS Bottom Freezer...
What does compressor getting noisy on ocaisson mean? Do I need to assume failure is immenient or could it last a while longer?
It is hard to say how long any appliance will last, but I would not replace solely for a noisy compressor. Most all compressors with age will get noisy on start up and shut down. If there is an espically loud knock on shut of check the mount bushings or for broken/lose mounting hardware
Sep 17, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
NAV6800AWW - noisy
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 04, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Noisy frig
it could be that your cooling fan gets noisy at times and stops for a while you could try to put oil on the shaft behind the fan this will help when it does get noisy pull the fridge kisten to the motor if noisy replace it its not to expencive about 40.00 dollaresthanks from gilles
May 12, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Noisy refrigeration without a icemaker.
Lift the arm up on the icemaker to shut it off some models have a switch on the side of the ice maker you can turn off as well a green indcator light
May 10, 2008 | Refrigerators
Feb 26, 2007 | Amana ABB2227DE Bottom Freezer...
Amana ABB2227DE Bottom Freezer Refrigerator Logo
317 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
