Question about Microwave Ovens
LG Microwave LMVM2055ST Just stopped working!
I was using my microwave and it just stopped, no power at all. Checked Circuit breaker and nothing was blown. Does this microwave have a fuse that possibly needs to be replace? Microwave is just over a year old. Mine just did the same thing. It just stopped working. The outlet has power, but the microwave does not.
  • 1 more comment
  • 8596randy Dec 11, 2008
    my lg microwave oven model # lmvm2055st just quit power is good at the outlet, but microwave has no lights it dead.
  • Anonymous Apr 02, 2009
    LMVM2055ST Just stopped working!"
  • delflash May 19, 2009
    same as described by other, ran for about 15 min. and just quit. acted like a fuse had blown, checked CB and also checked for power at receptacle.
  • Microwave Ovens Master
  • 9,098 Answers
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics. You'll probably have to call them.
Posted on Dec 13, 2008
It has probably had an overhesat problem and the repair is quite simple. First you must remove the cover. This will require the removal of alot of scres on top, bottom and rear of machine. Once done, looking down at the top of the microwave all the way to the left about half way from the front to the rear you will see a round senso with two black wires going to it. This issimilar to a fuse and when you remove it, you can test it with a continuity testor. Electric should flow through it with no resitance. If it does not, it must nbe replaced. It's about ten bucks.
Posted on Nov 20, 2009
I have a Sharp Carousel model R-1874-T. It suddenly stopped working. No lights are on. I checked the outlet and there is power coming there. Is there a way to reset the microwave?
Steve,
You probably have a blown fuse.
Unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 27, 2015 | Sharp Microwave Ovens
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
It just has no power. Nothing happened, I just went to use it and it was dead.
The main fuse is blown, "ceramic type" usually caused by a defective door switch.
Apr 14, 2011 | Maytag MMV4205 Microwave Oven
Yesterday the microwave was working fine, this morning nothing at all...No power at all. I have checked the circuit breaker and everything is fine. The oven below it is on the same breaker and it works...
it sounds like the internal fuse has blown. if your handy, it can be done , however,,MAKE SURETO
DISCONNECT THE POWER SOURCE BEFORE BEGINNING. if your not 100% comfortable
have a trained technition service the unit...
Nov 20, 2010 | Whirlpool GH7208XR Convection / Microwave...
My Microwave just died. I hit Stop/clear and it stopped all power. I checked the circuit breaker and the switch, it is good.. Any idea what happened?
Remove the case ... look for then check the fuse you will find on the floor of the device. If it is blown, find a replacement at your local hardware store.
Oct 29, 2010 | Viking VMOC205SS Microwave Oven
Microwave is NOT coming on. I have checked the circuit breaker which is fine. I also disconnected power and conected back
The most likely cause is an internal fuse which has blown. This can be replaced with a fuse of the same volt/ampere rating. Note that a blown internal fuse is most likely due to a fault on the oven's power circuit and further inspection may be neccessary.
Please feel free to contact me for any further assistance.
Best wishes,
Graemevm
Jun 18, 2010 | GE Monogram ZE2160SF Convection /...
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
Microwave Ovens Logo
1,977 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
