Question about Canon PIXMA MP830 All-In-One InkJet Printer
Wont recognize cartridge
When changing ink cartridge #5 printer does not recognize. Now all wont light up. We tried taking all cartridges out, turning off printer, restarting , even unplugging it. We bought another cartridge thinking it was faulty cartridge. What else can we do???I have three mp830 printers in my office and two of them won't recognize ANY of the ink tanks. (even thought the red indicator lights ARE lit). The error message is U043 "The following ink tank cannot be recognized" and the LCD screen shows a diagram of all 5 tanks. An on-screen message repeats the warning and lists all five tanks by color.
I've tried swapping the print heads and ink tanks to the one machine that still works and everything works in that particular printer. So, I know that the problem is not in the print heads or the ink tanks, but rather in the printers themselves.
I've tried powering them off, which does nothing. This is very frustrating. They ain't cheap machines.
Any suggestions would be appreciated.
  • 734 Answers
Answer: The copper-colored strip that has the dots on it is the connection between the printer and the cartridge. Just handling this during the refilling process will sometimes cause the connection to fail. A faulty cartridge will also cause this problem.
Solution: Clean the contacts on the cartridge with a cotton swab, or cotton ball, and some alcohol.
Answer #2: The cartridge is too full of ink.
Solution: Only put in the amount of ink recommended in our instructions. If you have put in too much draw some of it back out. Draw it off the top and not the bottom of your cartridge. In other words, only insert your needle about half-way into
Posted on Dec 09, 2008
    Genius:
  • 2,035 Answers
Check the copper contacts were the print head connect to printer whip it with dry tissue and then install the print cartridge ,even this fails clear all the memory in the printer then try to install ,if this fails then there problem with printers its needs to be serviced .....
Good luck...
  • 4,806 Answers
The U043 error message means there is a problem with one of the ink cartridges and the printer doesn't recognise it or there is a problem with the chip, take the cartridges out and clean them also clean the cradles they go into and try again, here is the manual for you to troubleshoot this problem:
http://www.instructionsmanuals.com/u2/pdf/multifuncion/Canon-PIXMA_MP800-en.pdf
kind regards
    Genius:
  • 1,011 Answers
Sir,
Call the Canon authorised service agent if u have any warranty. This is the problem with board and carriage unit.
So the problem was not with the ink tank after all.
Better to replaced the carriage unit and the main PCB board. The carriage unit is where the print head and ink tanks are sitting on.
thanks
good luck
  • 837 Answers
Try cleaning the contacts of the cartridge assembly and cartridges themselves with alcohol dampened wipes until they come clean.
  • Jay Glendenning
    Jay Glendenning Dec 09, 2008
    1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
    the Stop/ Reset button.
    2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
    service mode. (Waiting for menu selection)
    4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
    function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
    orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
    The number of the Reset
    button pressing
    LED Function Remarks
    0 time Green Power off
    1 time Orange Service pattern print
    2 times Green EEPROM print
    3 times Orange EEPROM reset
    4 times Green Waste ink counter reset
    5) Turn off the printer.( it must be turn off)
    then turn it on again.
Changed ink cartridges and light wont go out saying its still empty graham
could be an issue with the system drivers .. if outdated .. they wont be able to recognize the change.. else it could be faulty cartridges .. try cleaning the copper head and reinstall ..
if that does not help .. then call 1-877-805-1027 for expert help
Jul 23, 2015 | Epson Stylus Office Equipment & Supplies
Ink light on changed ink still wont print
it sounds like the printer has not accepted the changed cartridge.
Try turning the printer off at the mains for 30 seconds then back on again, it sometimes works, or if that fails take out the cartridge's turn off printer for 30 mins then back on re insert inks and see if that works.
If it fails then there could well be a chip set failure on the cartridge you have replaced or maybe another cartridge within the set.
It's well worth saving the cartridge too as compatibles sometimes fail to be read by your printer but rarely the actual cartridges fail, you can put that same cartridge back in later for it to be accepted by the printer.
Jan 15, 2014 | Epson Stylus Photo R260 InkJet Printer
Wont except aftermarket printer cartridge error code "not recognized"
May be the cartridge is not detected by Kodak printer. Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges.The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
May 23, 2009 | Kodak ESP 5 Printer
I just replaced black ink cartridge and snapped all cartridges back in place and recharged the printer now it wont recognize the black ink cartridge even though it was just replaced
Try wiping the copper contacts on the new cartridge with a dustfree cloth dampened with some alcohol. Dry thoroughly before reinstalling.
May 05, 2009 | Office Equipment & Supplies
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Ink cartridge changed but computer will not recognize it has ink
Please try the following in an attempt to resolve this issue:
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button.
4. Open the CARTRIDGE COVER. Pinch the front and back tabs of the first cartridge, and remove it from the printer.
5. Place it back into the holder. Push it down gently into the holder, until the cartridge clicks into place.
6. Repeat steps 4-5 for each cartridge. Close the CARTRIDGE COVER once all of the necessary ink cartridges are re-seated.
7. Carefully lower the scanner, until it clicks into place
8. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
CAUTION: Never turn off the printer while the ON light is flashing, unless the printer hasn't moved or made noise for more than 5 minutes.
Aug 30, 2008 | Epson Stylus CX4200 All-In-One InkJet...
i know this does not help solve the problem,
but it lets people know that this is a common problem.
Jun 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 150 error 5
Our pixma MP150 printer has a flashing E and flashing 5, also flashing on alarm, black ink and color ink. We have replaced the ink cartridges but nothing happens. They were empty. The printer doesnt recognize that the cartridges are there. We have tried unplugging the cords and taking the cartridges out and putting them in again. Also, it wont scan a thing either. ITs likes its frozen in the error. What can we do to fix this?
May 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
91 people viewed this question
old marine
old marine
