Question about Copystar Office Equipment & Supplies
I need the paper tray (the one after printing for a Copystar cs-1435
    Genius:
  • 2,120 Answers
You will have to call a CopyStar dealer or a Kyocera-Mita dealer to get that part.
Posted on Dec 09, 2008
Paper is not being pulled from tray properly
Change your drum unit, it seems the drum is spinning good, let me know where the jams happen! In the fuser unit! in the cassette!
Dec 05, 2011 | Kyocera Copystar CS-1820 Black and White...
Macbook Pro will not connect to Copystar 2550
ok... I am tech... and I had the same problem... you need to install the generic postscript driver then goto this ip address (http://localhost:631)and tune the driver... if not you will only print from tray 1 and only a4 paper size...
Oct 27, 2009 | Copystar CS-2550 All-In-One Printer
E33 Error Message
Im pretty sure the E33 error means the toner is empty, so you need to replace the toner.
If you have already done this, make sure everything is correctly seated and firmly closed.
Here is the manual incase you get any other problems, page 95 addresses your mentioned problem..
Copystar CS-2020 Manual
Regards
Mike
Sep 03, 2009 | Copystar CS-2020 Copier
PAPER TRAY JAM
Hello sir;Pull out the tray look inside the machineif you found any paper chip emove it otherwise clean out paper pickup roller with rubbing alcohol.
Jun 01, 2009 | Kyocera Copystar CS-1820 Black and White...
Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
Mar 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Red and blue marks on copies
The CS 2050 is a mono color (black only) copier. There is nothing within this machine that I have EVER seen that has red and blue "ink" in it. I suggest you look at the paper that is in the tray itself. I have been on many service calls where the customer said the copier was tearing off a diagonal corner of the page, or the copier was putting something on the page that it was not capable of doing. When I looked at the paper in the tray I would find that the paper itself had the defect before it ever even went through the machine. Since there is 500 sheets per ****, and you may only see it on every 20th or 30th copy, you will have to either just try a new **** or go through whats in there 1 sheet at a time looking at both sides. But, if you find something that has blue and red ink within this machine please let me know.
Nov 24, 2008 | Copystar CS-2050 All-In-One Printer
Set the eject tray
is there a job seperator on this machine (gray tray in middle of paper eject)? If so try this...Press */language key @ left of control panel...Scroll down to "Machine default", press enter key...enter code 2000 or 6482...scroll to ejector of fax (if equipped) or ejector of copy...select what tray ...scroll up to "end"...press enter...that should bounce you back to "Ready to copy" screen.
Jul 06, 2008 | Copystar CS-2030 Copier
Kyocera CS 2030 fax jams
Hi,check settings for fax.Try to check paper attributes for fax.Maybe You have different paper format adjusted for fax printing.
Oct 19, 2007 | Copystar CS-2030 Copier
46 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
