Question about Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television
PT-45LC12 wont power up
I have a pt-45lc12 that is about four years old. when I try to start it up, the green light will flash for about 10 seconds, then switch back to red without the picture coming up. you can hear the fan start up as well, and a faint clicking sound. I never got a message that it was time to change the bulb, and I cleaned the filter regularly. any suggestions as to what might be the problem? Thank you. Greg
  • greg breedlove Feb 27, 2007
    thanks for the advise, tvtek. I'll try it out and let you know how it goes.
    President:
  • 1,284 Answers
You have a bad lamp. The "clicking" sound you hear is the ballast (lamp power supply) attempting to start the lamp. The warning on Panasonics that comes up on screen does so when the life expectancy of the lamp is approaching. Otherwise your "clicking" sound and the red light on front are saying bad lamp. When you replace the lamp remeber to follow the instruction that Panasinc provides with the new lamp on restetting the lamp timer. This is usually done with the volume down on the TV and the PIP button on the remote.
Posted on Feb 27, 2007
New Bulb... No Screen...
Ballast Board ,it is what turns Lamp on! Call Encompass Parts for Part or look them up online they have website. Call 1-800-638-3328 Ok I looked it up Part# is LSEB3062A1 which showed No Longer avaliable,So try UED 1-800-648-6657 and Look on E-Bay under Electronics For Ballast Board.
Nov 19, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Pt-45lc12
It looks like a problem with a tube (projector light) I suspect the green one. Pay attention to flickering on the lights and post me the results.
Nov 01, 2007 | Panasonic PT-45LC12 45" Rear Projection...
How to reset the lamp for pt-45lc12
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
Jul 25, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Pt-lcx65 lamp light blinks every four seconds Help!!
If it si the Temp Lamp, the unit is indicating overheating. Check to see filter is clean and vents are not obstructed.
Jul 02, 2009 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12 just turned off?
having the same problem, after some research, came across this: http://www.fixya.com/support/t142873-panasonic_pt40lc12_blinking_green_power
Not a tech, so I'm going to look into it further on how hard this is to do.
Jun 27, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 45
yup.
cut it and jump the wires.
Jun 17, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Pt45lc12 45
you have to remove all the screws on the rear base of the set,and underneath the speaker grilles,then separate the front and back.
Jun 15, 2008 | Panasonic PT-45LC12 45" Rear Projection...
PT-45LC12 Problem after startup
When the lamp flashes 4 times this is what the error code means IC 2301 pin 11 has detected an LCD error which is caused by an error in the LCD power CBA. which means the lamp voltage has become more than 130 volts or less than 30 volts. Or the lamp current is more than 5 amps, or the lamp is cracked. Its one of thos 3 reasons that will make the lamp indicator blink 4 times. Hope this helps. If you need the service manual for this model you can get one emailed to you from the following link.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Blinking green power light..no picture
disconnect the power cord overnight try it if ok change power cord cheers
Jan 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
My PT-45LC12 has picture and fan problems
More like lamp failure. Could be other things of course but start with the lamp cause it will need it anyway if has been a couple years.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Jan 10, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic PT-45LC12 45" Rear Projection HDTV-Ready Television Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
