Question about Xerox Phaser 7300DN Laser Printer
Horz. streak approx.3/4 down on each page I print
The streak is always in same place. Looks like a light streak put streak color is like a real light magenta color. When I go to the menu on printer and check magenta toner life it says it's low but normally when I have to replace it I get a message saying too so I don't think that's the problem. The magenta imaging unit says it's ok too. Transfer and fuser life says ok too. Any ideas?
    Scholar:
  • 99 Answers
Sounds like some of the magenta toner is left behind on the drum. The only way to fix it is to get a new cartridge.
Posted on Dec 09, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
I am having a very similar problem, except with black instead of magenta, and mine is a phaser 7760. The line is perpendicular to the direction of paper travel right? Have you had any luck solving this? Thanks.
Posted on Jun 05, 2013
    President:
  • Xerox Master
  • 1,314 Answers
From the service manual:
Dark Streaks in a Single Color or All Colors in the
Direction of Paper Travel
.There are dark lines running along the page in
the direction of paper travel from the leading
edge to the trailing edge
This is generally due to fuser, paper path roller
and/or exit guides contaminated with toner
debris.
Troubleshooting Procedure
Step Check Yes No
1 Run the Remove Print Smears routine from the
printers front panel.
Did this fix the problem?
Complete Go to step [2].
2 Are there any obstructions, dirt or debris in the
printer’s paper path.
Check for toner spills inside the printer.
Clean and
remove
obstructions.
Go to step [3].
3 Visual inspect the Imaging Units and rollers for
signs of damage.
Note: Exposure to light can damage the
Imaging Unit, examine the unit quickly
and out of direct sunlight.
Replace the
defective
Imaging Unit.
Go to step [4].
4 Check the Fuser where paper enters for spilled
toner or contamination.
Clean if dirty. Did this fix the problem?
Complete Go to step [5].
5 Verify the ribbon cables and wiring harnesses
on the LED Heads are seated, connected and
routed properly.
Go to step [6]. Reseat, reroute
or replace any
damaged wiring
harnesses.
6 Generate a service test print pattern from within
service diagnostics. This will test the Engine
Controller Board.
Did the test pattern print correctly?
Replace the
Image Processor
Board.
Replace Engine
Controller
Board.
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
Vertical streaks but only on first 2-3 pages
replace the image units associated with the color of the streaks
Apr 17, 2017 | Konica Minolta Magicolor 4690MF...
Color doesn't look like what is on computer screen... printing from InDesign and Photoshop... same results from each program.
first of all, your screen is probably not correctly calibrated to show the colors right. Same goes for your copier, try calibrating the colors. Press the menu button (it's a button next to the screen, looks like a star with a head around it)
- Then press Adjustments/Cleaning
- Auto Gradation Adjustment
- Full adjust
- Print page 1
- Put the paper on the copyglass, with the black toner facing the back of the machine.
- Press Scan
- Then Print page 2
- Scan page 2
- Print page 3
- Scan page 3.
Now the colors are calibrated. If it still doesn't match, try calibrating your computers screen so you can see the real colors.
Dec 21, 2010 | Canon imageRUNNER C3220 Color Copier
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
Magenta leaving a colorless streak
You need to check with Xerox , ther is some toner that was manufactured last year (2008) that was defective
the phone number for xerox support is 503-682-7377
Apr 01, 2009 | Xerox Phaser 7760/GX Laser Printer
Streaks on color copie
You must pull 2 sided glossy from the stack bypass and set on color paper.
Apr 11, 2008 | Canon CLC 1120 Color Copier
Color Streaks down length of page
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
Scanning trouble PLEASE HELP!!!
1. does scanning from the pc looks good ?
2. printing photos from the pc looks good ?
3. does standalone copy (placing image on the scanner bed then pressing the COPY button on the printer) looks good ?
Dec 31, 2007 | Epson Stylus CX7800 All-In-One InkJet...
Xerox Phaser 7300DN Laser Printer Logo
393 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
