Question about InFocus LP 530 Multimedia Projector
Image is upside down
I have a ceiling mounted Infos LP530. Today the image is upside down. Where do I go to invert it? Thank you
    Scholar:
  • 99 Answers
Hit the menu/select button to bring up the menu either on the projector or on the projector remote then go down until advanced is highlighted then press the menu/select button then move down until Ceiling Project is highlighted and hit the menu/select button again to get the image right side up. If you have the manual for the projector this information can be found on page 34.
Posted on Dec 09, 2008
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
Will turning your television upside down damage your television?
No it will nNo it is not. In fact some televisions are designed with this in mind. Usually this is done with smaller televisions that will be mounted. On those televisions there will be a picture flip or reverse image/invert image setting. I have spoken with bewildered seniors with upside down pictures and advised them to simply press picture flip until their image is right side up again. There are some customers that mount their televisions in bathroom mirrors or on the ceiling, under kitchen counters, and etc. who have found this to be most helpful.
Jun 13, 2011 | Televison & Video
The ceiling mounted projectors image is upside down, how do i turn it the other way?
Go to the menu, in the "Setup" section, then go to "orientation"..and select "ceiling"...image will invert for you.
Good Luck
Aug 12, 2010 | NEC MultiSync VT580 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Why is image upside down? the image appears inverted on the board
You need to set up the image using the menu. Press menu button on the remote then use the arrows to go down the list until you come to "mirror". Now press the enter button on the remote several times to cycle the orientation of the image (on some remotes you may have to use the right arrow button instead of the enter button). The projector will remember this setting next time it is switched on. These options are there for people who use ceiling mountings that hold the projector upside down.
Jul 10, 2009 | Epson EMP-S3L LCD Projector
Image upside down
Check in the settings. One of them will have the option to invert the image not sure what it will be called. That should flip it upside right. I had the same issue with my projector when I first got it just messed with menu until i found it.
Feb 11, 2009 | Epson (V13H010L13) Projector Lamp for...
Nec projector
go into menu, under image, and chose ceiling.
Apr 08, 2008 | NEC VT37 Multimedia Projector
Reverse Image
find the menu for saving the settings, for sure there is a menu saving all your desired settings. good luck!
Feb 11, 2007 | Mitsubishi X490U Multimedia Projector
InFocus LP 530 Multimedia Projector Logo
461 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
