Question about Motorola FV200AA GMRS/FRS 2-Way Radio Walkie Talkie with 5 mile Range
Lost manual - can only get one T3 radio to transmit
I have set both radios to channel 3. I can get one radio to transmit and the other to receive, but not visa versa. I have searched everywhere online for the manual. Pls help.
  • Motorola Master
  • 1,654 Answers
Http://www.motorola.com/mdirect/manuals/fv200_userguide.pdf
Check your Interference Eliminator Code.
Posted on Dec 10, 2008
  • alberto gai Nov 20, 2012
    I have a similar problem: What does 'check your interference eliminator code' means?
  • eradiostore
    eradiostore Nov 21, 2012
    Your radio would have both a frequency and a code. The CODE is different than the frequency. It is another filter which allows the radio user to only communicate with other radios using the same code. In most Motorola TalkAbout radios this is referred to as Interference Eliminator Code. Other names are PL, private line, quiet call, or tone coded squelch. Basically if you have one radio set to a different Code number than the other unit, your radios will not communicate. If you supply the name/model of your radio, maybe we could post a line to the user guide, where this would be better explained.
Talkabout MH230R does not Receive or Transmit on channel, can just Transmit (only clicks when Recieve) when programmed 2 channels higher (i.e. all radios on 5-3, one is on 7-3)
Strange. Could it be any of the radios are from different countries? The channels are not worldwide. For instance, Canadian radios are on different frequencies than USA radios. They look identical.
Dec 30, 2015 | Motorola Talkabout MH230R 2 Way Radio
Doesn't transmit
Check your battery. Transmitting takes more energy than receiving. Also, check your frequency and code settings. The radio you are using this one with might have a different code setting than yours. http://shop.giantintl.com/Manuals.asp
Feb 13, 2014 | Motorola Talkabout T5720 (7 Channels)...
Motorola TLKR T3 one way not working but Monitor works...
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Nov 20, 2012 | Motorola Radio Communications
Hi, i have 2 TLKR-T3 and i cant tune it ,so what can i do? and how can i reset it? thanks in advance
Try setting the radio back to a simple mode of operation. Shut off all special features such as the sub-code (interference eliminator code), VOX, room monitor, and call tones. Go to just one basic channel, such as channel one. Then check to see if the radios talk to one another. If not, check your battery packs, as it takes more energy to transmit than to receive. Swap battery packs and see if the problem moves to the other radio. And lastly, get a third radio involved to see if one of your radios is simply defective.
For your convenience here is a link to the user guide: http://www.gouldelectronics.co.uk/product-downloads/T5-20Manual-20EU.PDF
Best regards.
Aug 31, 2011 | Motorola TLKR T5 Two Way Radio
Need a service manual need to modify a MR f55 radio to transmit on 161.600 mhz can you help?
You want to be able to transmit to the Coast Station on this frequency I assume. The Coast Guard monitors channel 16 at all times. This would be the primary channel in the United States. Your radio is VHF Marine Radio and has a built in frequency range of 156.050 MHz to 163.275 MHz. There is no need for a modification. This is a duplex frequency. What that means is you will transmit on one frequency and receive on another, while on channel 20. You will not need to transmit on 161.600. Turn your radio to channel 20. When you transmit, you will transmit on 157.000. And when the Port responds to you your radio will automatically receive their signal on 161.600. So if you are trying to figure out how to communicate with the port authorities then for that frequency turn your radio to channel 20 and you will be able to communicate with them.
Regards, Tony
Mar 31, 2011 | Cobra MR- F55 Base CB Radio
I can't get the radios to communicate with eachother, they have power and chirp when I press the talk button but nothing is being received.??? They look like the EM1000 model of Motorola radios. The FCC...
These are multi-channel FRS / GMRS radios. In order to receive transmitted signals from the other radio, they both must be set to the same Channel and the same Interference Eliminator Code. One without the other will keep audio from being heard on the receiving radio.
I suspect you need to refresh yourself with the radio's controls and settings. If you have lost the manual, you can get a copy free of charge from Motorola You'll need a free program called Adobe Reader to view it.
Once you have everything - look at the right hand side of page 1 for "Talking and Listening" followed by "Menu Options" to set the radios up correctly. Keep in mind that if VOX is selected, and there is sound near both radios, they both will transmit at the same time - since the radios receive OR transmit at any given time, no audio will be heard from either.
Please rate this reply if helpful & good luck!
Aug 18, 2010 | Motorola EM1000R Two Way Radio
Motorola Talkabout FV700 not transmitting nor receiving
had the same problem...took out nimh...replaced with triple A...works great!!
Thank you!!
Dec 26, 2008 | Radio Communications
Motorola T5420 Transmit Problem
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Aug 25, 2008 | Motorola Talkabout T5420 (14 Channels)...
FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Ken
Go Ahead. Use Us.
Apr 30, 2008 | Motorola Talkabout FR60 (14 Channels)...
Lost channels in a galaxy 66v cb radio
as far as the transmit frequency changing while you have the mic keyed this is normal, the transmit frequency is a little different than the receive, as far as the lost channels go you need to check the galaxy website and check to see if thier is any fixes listed. if none is listed then you can send the tech's a e-mail and tell them your problem and they will advise you on what to do.
Aug 15, 2007 | Galaxy Radios DX-66V Base CB Radio
Motorola FV200AA GMRS/FRS 2-Way Radio Walkie Talkie with 5 mile Range Logo
406 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
