Question about Acer Aspire 3690-2196 Notebook
Toshiba Satellite A300 blank Screen with cursor Vista won't load
When I turn on my notebook I get a blank screen and just a cursor, no error messages or anything. Windows Vista doesn't load.
  • Anonymous Mar 28, 2014
    Home icon gone, can't get off front screen, can't do anything, blank space with flashing cursor like it needs password
    Problem Solver:
  • 12 Answers
Compatability Issue with Vista.
Likely to be a Hard Drive Issue.
Posted on Dec 09, 2008
The case is: I shut my laptop " satellite a300 Toshiba" off by the button, and I did not wait it until shut down normally. then, every time I try to turn it on again it starts normally and...
That pointer is there to notify you that no operating system was found - Windows has been completely corrupted when you have shut it down while it was still working. Just reinstall it and all will be back to normal.
May 18, 2011 | Toshiba Satellite A300-ST6511 Notebook
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
When I turn my Toshiba A45-S151 laptop on, I first get the screen that shows the Toshiba logo and has the four icons under the logo. Usually the next screen is black, has a cursor in the top left corner,...
That blinking cursor is the way in which the BIOS is telling you that Windows is not loading because its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 18, 2010 | Toshiba Satellite A45-S151 Notebook
I have a Toshiba satellite pro A300 which when it is powered up shows the 1st screen with options for setup etc using F2 and F12. The laptop responds to neither and goes to blank black screen with a white...
Hello,this is a common problem that is caused regularly from a virus or a software/driver that you have recently added and caused this.The first you must do is to try to boot from safe mode(pressing F5,F8) while you booting and enter safe mode and remove anything you installed recently.Also you can try to select Last Know Good Configuration.If non of this helped you must reinstall or repair the operating system.Am waiting for your reply.Good luck
Feb 04, 2010 | Toshiba Satellite A300-0CF035 Notebook
Toshiba Satellite Pro L300 PC Notebook Blank blue screen. can't reach to desktop after loading windows. it have vista premium
It is a problem with Hardisk & RAM.first you can checked it reinstalled the OS.if problem does not solve then checked it repace the another RAM & hardisk.
Oct 26, 2009 | Toshiba Satellite Pro L300 Notebook
Windows Vista Will not load correctly
sounds like you have some corrupted files in the boot sector. 2 options.
1. using a vista dvd: let it boot from dvd and when it is loaded select the repair my computer option. once you get up and running use malwarebytes and superantispyware to remove any nasty bugs that you may have caught.
2. using your recovery partition do a system recovery this option restores your pc back to when you bought it.
Aug 29, 2009 | Toshiba SATELLITE Notebook A205-S5813
Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Loading problem
I take it you see the hard drive when you boot to vista cd. doing install can you remove partition and then create new partition format and install vista software. have you tried that if so sounds like your hard drive is working and can delete and reset drive partition index. if your crashing in post then you need to push the tab key when toshiba logo appears should switch showing post BIOS boot on screen all text you should try pressing the setup key as soon as you see the num loc light blink on your keyboard the driver is loaded press f2 then tab key to check post boot.
please let me if this helped you.
Mar 21, 2009 | Toshiba Satellite A300-0CF035 Notebook
Windows will not start
start your system in safe mode...
and run the scan pressing instant scan...
Here is the link
Apr 05, 2008 | Toshiba Satellite A15-S127 Notebook
Acer Aspire 3690-2196 Notebook Logo
385 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
