Question about Toshiba SD-V280 DVD Player/VCR
Freeze up on DVD
DVD will load and play, however, during the play the screen begins to freeze and motion is very slow (this could happen at any time). Small square blocks appear on the screen and there may be slight movement on the screen showing two different scenes (distorted) at the same time. Finally the screen will completely freeze up and nothing will get it to move. I cleaned the discs with approved solution and cleaned the DVD player with compressed air. The DVD player is relatively new.
  • ghostfist Jun 30, 2008
    ...also my DVD player gets really hot. Could this be affecting performance? It has been performing okay except when left on.
    Genius:
  • 1,074 Answers
If you are a tech check the voltage regulator the problem is intermittent ytou shold be getting about between 5to 12 volts dc from the output of your regulator.if you are not getting that then rplace the voltage and the associated components if you are not a tech take it to one and have it repaired.good luck.
Posted on Mar 23, 2007
  • Henry  Thomas
    Henry Thomas Mar 28, 2007
    you can also spray some feeze it on the microcomputer and blow it a fan during play back and see what it does if it return to normal then the micro is bad replace it.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Hi vaffl I read your symptom this morning and it sounds like you might have a tracking problem. In order to confirm this problem remove the top cover. I would start by measuring the power supply voltages. Load a disc in the player and press play. See if there is any change in the voltage levels durring the time that the player starts acting up. Sometimes a faulty voltage regulator will cause this problem. I hope this helps you. Bruce
Wii freezes and console makes a high pitch buzzing noise
Same Problem.. I have wii softmod. Never had any problems, except the black ops loading screen freeze, which I fixed.. Now, when I play multiplayer, team deathmatch, it freezes with a loud buzzing sound in mid battle.. Some 1 help please!!!
Jun 06, 2010 | Nintendo Wii Console
The player either freezes completely or pixelates during playback
I think the problem is for this the disc may be damaged. Or dont use copies this freezez and ruines the system, there may be a microchip problem i sugest return it and ask for compesasatin
Dec 21, 2009 | Samsung BD-P1500 Blu-Ray Player
Xbox 360 Freezing during netflix and dvd playback
If you are using a HDMI connection, often the connection will be lost between your xbox and your tv. In my case I simply change to another channel or the other HDMI channel and then back and the secure HDMI connection will be restored.
Aug 05, 2009 | Microsoft Xbox 360 Console
Quickplay on laptop plays everything slow motion and no sound, no sound for games most of time.
Are you running xp or Vista?
In XP go to device manager and expand list of IDE ATA ATAPI controllers. Right click on primary IDE controller and select properties. In advanced screen check primary IDE mode - that should be DMA.
IF that is in PIO mode - that is your problem.
Just click on driver tab in the same window and click uninstall.
REstart computer twice and problem should be solved.
Please leave your feedback if issue is solved
May 28, 2009 | Computers & Internet
My XBox 360 freezes
Well if these spot are consistent on certain disks time after time it is most likely a scratch, smudge or defect on the disk. check them all for scratches and if they are dirty try to clean them very gently with a soft cloth. This would only really concern your actual console if it occurs during heavy game loading or at the same spot during a load. Try cleaning all your disks and get back to me. GL
May 26, 2009 | Microsoft Xbox 360 Elite Console
My PS2 will play the games for a little then they will freeze.
try using a q-tip with rubbing alcohol to clean the lens of the laser.the lens is exposed on the slim versions.just dip the q-tip in the alcohol and rub the lens firmly in a circular motion.use the dry side of the q-tip to dry the lens
Nov 14, 2008 | Sony PlayStation 2 (PS2) Console
Ilo dvdr04 freezing picture
have you tried using a laser disc cleaner after alot of use the laser eye can become dusty and make it hard to read
Aug 24, 2007 | iLO DVDR04
DVD Recorder
During MY long, intensive, painful research concerning the EXACT same problems, I've discovered that in ONE circumstance, these problems are caused whenever the recorder has INPUT (COAX, AV, etc), from a CABLE box!!!! Assuming the controls haven't already frozen, I disconnected the CABLE box from the recorder, and the recorder "came back to life!!!" And this, after bring my recorder in for "repair", THREE TIMES!!! Now, the only thing to resolve is: how to connect the CABLE BOX to the recorder--WITHOUT using any of the recorder's input jacks!!!! Progress, right?
Mar 11, 2007 | Panasonic DMR-EH50 DVD Recorder
DVD player freezes
If it's a very cheap unit, it's possibly because the machine can't process the information quickly or efficiently enough, thusly causing the picture to freeze up while the processing catches up with it. Friend has a $30 unit, which happens to constantly.
Nov 07, 2006 | Sanyo DVW-6000 DVD Player/VCR
Toshiba SD-V280 DVD Player/VCR Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
