Question about Konica Minolta bizhub 350 All-In-One Laser Printer
HI , I have a Konica Minolta Bizhub C350 I want to connect this printer to my computer please guid me what is : Internet protocol (TCP/IP) Properties and preferred DNS server No. and Alternate DNS server No.
  • Dan
    Dan May 11, 2010
    TCP/IP is how equipment communicates on a network. Each piece of equipment has it's own IP address.
    DNS is how the same equipment can find an IP address by using a proper name.
    For example: My printer's IP is 1.2.3.4 and it's name is Printer1. The DNS will translate "Printer1" into 1.2.3.4 so you can print to it.
    My question to you:
    Will this printer be connected direclty to your pc ouor will it be on a network?
    New Friend:
HI , I have a Konica Minolta Bizhub C350 I want to print paper A4 color. please guid me
Posted on Dec 31, 2014
    President:
  • Konica Minolta Expert
  • 347 Answers
The settings you are asking are for the network printing, simple stand alone usb printing does not need these settings, first of all go to "ADMINISTRATOR MODE" then in this mode, Select 5th option which is "NETWORK SETTING" in this option enter your desired tcp/ip and DNS addresses.
Posted on Jun 19, 2010
    Problem Solver:
  • 17 Answers
GUIDE IS AVAILABLE ON WWW.MYKONICAMINOLTA.COM
Posted on Jul 07, 2009
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
I WANT TO BE ABLE TO PRINT FROM MY COMPUTER TO MY PRINTER
  1. Either set a static IP for the printer or attach your computer directly using USB.
  2. Setup the printer on your computer using the driver for the printer. If the printer has Postscript capabilities the PS driver is better than the PCL driver.
  3. If the printer is USB setup like any other printer, if the printer is IP then specify a local port in the Wizard and type the IP.
  4. Choose the driver and install
  5. Afterwards go under properties and select the printer components such as duplexer, extra trays, etc.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I install Konica Minolta Bizhub C350 copier using a router and 1 computer with Vista 32-bit?
To setup LPR Printing, perform the following:
For Windows 2000/XP/Server 2003:
1. For Windows 2000, click the [Start] button, point to Settings, and then click Printers.
2. For Windows XP/Server 2003, click the [Start] button, and then click Printers and Faxes.
3. Right-click the icon of the installed printer, and then click Properties.
4. On the Ports tab, click the [Add Port] button.
5. In the Available Printer Ports list, select Standard TCP/IP Port, and then click the [New Port] button.
6. When the Add Standard TCP/IP Printer Port Wizard starts up, click the [Next] button.
7. In the Name of printer or IP address box, enter the IP address for this machine, and then click the [Next] button.
8. Select Custom, and then click the [Settings] button.
9. Select LPR, enter Print in the Queue Name box, and then click the [OK] button.
10. Click the [Next] button, and then click the [Finish] button to apply the setting.
Oct 05, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I need the default ip address for the Konica Minolta C350
Press the Utility/Counter button.
Administrator Settings - password is 12345678
Network settings
TCP/IP settings
Oct 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
How to hook up
just install it with tcp/ip protocol if possible.
Mar 12, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
585 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
