Question about ASUS Computers & Internet
Warning on post screen during boot up and ocassional blue screen
I get this warning on the bootup post screen "A 200MHz System Bus Processor is installed and is not supported by this system and will run at a reduced speed performance will be impacted . In addition to this i am getting a blue screen flash by - the computer then reboots and may be ok for a while then the problem will repeat . My system is a Asus P31 Neo V2 series MS 7392 (V1-X) main board ,a dual core E2180 2CHz FSB 800 1Mb processor, a GeForce GTX 260 graphics card , a 550 watt power supply and 2 Gig of ram all brand new and fitted by a computer shop who are now not being to helpfull Are you able to help
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    read the blue screen and post back what it says
    regards
    Scholar:
  • 99 Answers
Sounds like the CPU is overclocked in your system. I would clear CMOS the try it again. The CPU is probably overclocked to far causing it to become unstable.
Posted on Dec 09, 2008
Locked out from eee box 1035 need to reset bios how?
Try this. Right out of the manual. The reset button is the little pin hole next to the power. Will need a paper clip that is straightened.
Entering the BIOS Setup
BIOS (Basic Input and Output System) stores system hardware
settings that are needed for system startup in the PC.
In normal circumstances, the default BIOS settings apply to most
conditions to ensure optimal performance. Do not change the
default BIOS settings except in the following circumstances:
An error message appears on the screen during the system
bootup and requests you to run the BIOS Setup.
You have installed a new system component that requires further
BIOS settings or update.
WARNING!
Inappropriate BIOS settings may result to instability
or boot failure. We strongly recommend that you change the BIOS
settings only with the help of a trained service personnel.
Quickly enter the BIOS
Windows8 boot time is quite fast, so we developed the following
three ways for you to quickly access the BIOS:
Before booting up the system, insert a straightened paper clip
into the BIOS Reset key.
BIOS Reset key
Press the power button for at least four seconds to shut down
your PC, then press the power button again to turn your PC back
on, and press F2 during POSt.
When your PC is off, disconnect the power cord from your PC's
power connector. Reconnect the power cord and press the
power button to turn on your PC. Press F2 during POST.
Oct 16, 2013 | Compaq Presario 5000 PC Desktop
The following are warnings that were detected during this boot.These can be viewed in setup on the event log page.Warning: chassis instruction
the following warning that were detected during this boot. these can be viewed in setup on the event log page. warning- chassis intrusion
Dec 18, 2012 | Computers & Internet
Ok when i boot my system gives me option on whether to press f1 for set up or f2 to resume boot sequence,though initially it display a warning notification that no processor bios update was found
Soon as starting up press delete and it has to go to Cimo setup and go to bootup sequence and select it to bootup with Hard disk first and your Rom as second option.Thank you.
Sep 02, 2011 | Computers & Internet
Had a power failure in my area, my dell desktop was on at time. When I turned it back on I got blue screen which I know is not good. Decided to install new/bigger harddrive since I need to install windows...
Hi, you need to change your primary boot device, try pressing the F1 key during bootup, this will take you to the BIOS screen, from here you can change your primary boot device from HD to CD, save your changes, reboot, selecting boot from CD when it appears during bootup.
Hope this helps
Jul 21, 2010 | Dell (E210882) Motherboard
Dell 1150 laptop configuration module problem
Hi, you can perform a system restore by accessing safe mode by pressing the ESC button during bootup. Restore system to a time before the problem began. You will need to perform a full virus scan straight after normal bootup is achieved. Hope this helps
Jul 15, 2010 | Dell Inspiron 1150 Notebook
Compaq Preario V5245eu cant get past scrolling xp window just restarts and doesn'r get anywhere have had a c000021a fatal error warning- help please Rodger
If you attempt to install a piece of hardware or software on your PC computer that is incompatible with your system, you may see a blue screen with a C000021a fatal error warning. The easiest way to recover the Windows operating system from this type of error is to restore your computer to a previously working state.
1.Press the "F8" key on your keyboard when prompted during the boot process.
2.Use the up-and-down arrow keys to highlight the "Last Known Good Configuration" option. Then hit "Enter.
3.Use the up-and-down arrow keys to highlight the operating system version that you wish to boot up to, and then hit "Enter" again. The system will now restart to the last working version of your operating system, which will eliminate the C000021a fatal error.
Hope this helps
Mar 13, 2010 | Computers & Internet
During last bootup, your system hung for improper frequency combination. Your system is now working in safe mode. To optimize system performance & reliability, make sure the frequency combination ...
this is only a warning of computer bios., this usually happens if you overclock, or a power failure during POST of bios.. Just press the Restore/Default Setttings.. I think its F2 in some boards, itwill just reset the settings, it should be fine
Feb 02, 2009 | ASUS P4B533-VM Motherboard
Turn on, after intital screen with setup options the following appears: "SMART Failure Predicted on Hard Disk 4: SAMSUNG HM121HI - (S1) WARNING: Immediately back-up our date ....... Afailure may be...
Have you installed or attached any Software /Device since then.
Please unlug any device attached and then try. Also try tapping F8 key during bootup.
Check BIOS with F2, DEL or ESC key during Bootup.
Best of Luck & Regards Puneet
Oct 05, 2008 | HP Computers & Internet
Computers & Internet Logo
406 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
