Question about Sony VAIO PCG-TR3AP1 Notebook
REPLACE HARD DISK
SONY VAIO VGN-A397XP MODEL
I want to replace my hard disk drive
where can i find the technical manual
  • Anonymous Mar 29, 2014
    hard disk replacement
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Sony vaio error 333
Try deleting partition(s) and re-creating. This problem has been around for a while. It could be the hard drive, but most say it's the disc.
Sep 25, 2012 | Sony VAIO VGN-FW170J/H Laptop
I want to know about the model of Hard Disk drive which originally used for VIO VGN FS 740/W
Sony VAIO VGN-FS740/W PC Notebook Original Hard Drive Specification is 80GB, 4200rpm Ultra ATA (IDE Interface)
Please refer to Sony Official Documentation for more details (if required).
CreativeTECH
Dec 29, 2010 | Sony VAIO VGN-FS740/W Notebook
Dead hard drive
it will be real silm like and it will be on the side where the cd player is not you may have to unsrew to srews and it should just slide out
Feb 14, 2010 | Audio Players & Recorders
Sony Vaio VGN-NR498E recovery disk
Hello
Well, the recovery disks won't allow you to go to your present system. The recovery disks are designed to put everything back the way it was when you bought the computer, minus all your applications and data. If it's your data that you need then a reputable repair service like mine can slave your hard drive to another system and recover all your data (not applications), provided the hard drive has not electronically or mechanically malfunctioned. Again, a reputable repair person can tell you the status of the hard drive.
Thanks
Jan 07, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
OPEN Sony VAIO VGN-T330FP TO CHANGE HDD
turn the laptop upside down ...remove a partial plastic cover attached by a screw on its edge ( there is a small sign showing the hard drive usually) after taking the cover of plastic away the hard disk is visible . pull it gently aside (sideway)
and replace it with the new one.
May 29, 2009 | Sony VAIO VGN-T350 Notebook
Sony VAIO VGN-FJ3M/W does not boot.
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
Jan 10, 2009 | Sony VAIO VGN-FJ270/B Notebook
How do I have access to the hard drive on my vaio VGN-a150
hi my frieed l saw your messange in box the only thing you can do is that you need the change , Just change it? later
Jul 24, 2008 | Sony VAIO VGN-A150 Notebook
Sony VAIO PCG-TR3AP1 Notebook Logo
134 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
