Question about Car Audio & Video
Dvd wont play
Set the parking brake to play the dvd
  • 26 Answers
If you hooked the parking brake wire up, sometimes those units require a double pulse. meaning that you set the brake for 1 sec., release for 1 sec, then reapply. then there will prob be a 3 to 5 sec delay before you get video. try that and see if it works. If not get a toggle switch from a local auto store and hook the parking brake to one pin and ground the other. Then treat it as the parking break.
Posted on Jan 16, 2009
Wont play dvd
When you say, "won't play DVD", do you mean you cant see the movie or, the DVD is playing at all. If you can't see the movie, more than likely your parking brake wire needs to be grounded.
Aug 19, 2012 | Valor ITS-700W
Cant play dvd says parking brake on screen
you can not play dvd's when the car is not in park with the e brake on. I"m assuming it was factory installed or by a dealership??? they hook a line from it to your brake sensor. it's illegal to watch movies while you're driving. so long as theyre behind your seat and out of your view theyre legal, otherwise they hook it to your brakes.
Aug 14, 2012 | JVC Kwav60bt 6.1" Dvd Cd Mp3 Double Din...
My vm9510 wont play the dvd with out saying parking and screen blue
You have to connect the park wire of the Jensen to your hand brakes that gets a negative signal everytime you engage it or you can try to put in series the park wire to a switch and any ground. Then read your manual how many times you got to switch it on and off until the picture appears when your dvd is playing. Same thing if you connect it to your parking brakes you got to engage your parking brakes on for 1 or 2 secs then back off then back on again for 1 or 2 secs keep doing this varying the secs till you get a picture. That will be the sequence to turn off that blue screen and on the dvd to watch the movie. Read your manual very carefully it will tell you the same thing but you definitely have to hook up the brake wire or else you will never see the picture. Check the manual for the color of the brake wire or just find the longest wire on the harness and thats usually the brake wire.
Apr 07, 2010 | Jensen VM9510 Car DVD Player
Why my dvd wont play while im driving?
there is a safety wire that is hooked up to tell when the car is in park or p-brake is on.
Unpluging it is not safe for you or other drivers!!!!
Mar 14, 2010 | Pioneer AVH-P5700DVD Car DVD Player
I cannot play DVDs without the parking brake engaged how do i bypass this?
I ran across of alot of lcd head units that requiers the parking brake wire connected so it will show the video, (usually just audio if parking brake not on). But if you connect that wire to a proper ground (screen always on) or a grounded switch so you can control it maually (turn it on or off when you choose)
May 30, 2009 | Pyle PLD52MU Car DVD Player
Jensens VM 9312 car DVD player problem
Just go to the set up menu ( Your screen should say setup at the upper center of your screen ) Then press 5, 4, 3, 2, 1, 0 with your remote control and a second menu will apear, on your left side press the second option and select parking bypass to on.
Sep 03, 2008 | Jensen's VM9312 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
ITS just a ground cable hook it to the radio ground i did and mine works fine
Aug 21, 2008 | Jensen's VM9312 Car DVD Player
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
Parking brake
ground the pink wire that will allow player to play video
Feb 04, 2008 | Car Audio & Video
Wont play
Try resetting the unit by pressing the small, recessed button on the faceplate with the tip of a pen. If this doesn't work, the player may be defective. There is no wiring error (including failure to hook up the parking brake input) that will prevent the unit from playing CDs.
Mar 09, 2007 | JVC KD-AVX1 Car DVD Player
Car Audio & Video Logo
134 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
