Question about Nokia 6600
White screen my 6500 starts up then gose a funny colour and gose off if press a button it will flash then go off again showing the date can i sole this problem buy flashing the software on line??
  • Anonymous Dec 11, 2008
    white screen
  • 75 Answers
Ya try it out...or change the display..
Posted on Dec 09, 2008
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
I can not get alarm to work on Constant elite colour change LCD alarm clock
Underneath clock there is 4 buttons, 2 of which are marked (m) & (s) and the other 2 buttons marked with arrows for (up) & (down). depending if you have the clock, alarm or date showing press down on the (s) button for about 3 seconds and the hour digit will start flashing, use the (up) & (down) arrows to set your hour. Then press the (s) button again just briefly and the minute digit will flash and use arrow (up) & (down) buttons to set this also. Press the (s) button again and all will stop flashing and Alarm or Time or Date will be set. Hope this helps as i had same problem but figured it all out in about 2 minutes as i couldn't find my manual lol,.
Jan 27, 2011 | Vacuums
Time is correct but date and day is not. How can I set the correct date?
Press the SET button until the month if flashing. Then press the CH button until the correct month is showing. Press SET again so that the day is flashing. Press CH button until correct day is showing. Press SET so that the year is flashing. Press CH button until correct year is showing. Press SET until nothing is flashing. You should be done.
Jan 18, 2011 | La Crosse Technology Technology Weather...
I bought a new OfficeJet. How do I change the date
Hello and Welcome to FixYa!
You can change the Date on the front panel of Office-jet 6500 by following this;
  • Under the display window press the "Setup" button (located below and left of the "OK" button).
  • It should now show a "1. Help Menu".
  • Press the Right or Left arrow next to the "OK" button until you reach "6. Tools".
  • Press "OK" again and you should now see "1. Date and Time".
  • Press "OK" again and it should show "Enter date:" You will probably figure the rest but I will continue for continuity.
  • Below it will show "00-00-00" and "m-d-y". You won't need to enter the dashes(-), just the numeric month, day, and last two digits of the year.
  • Next of course will be the time (in 12 hour mode). Lastly it will ask to enter 1 for AM or 2 for PM.
  • I forget some of the specifics such as exactly when to press "OK" during the last parts but this should get you where you need to be..
Note: the little columns under the date are ink levels so don't let this confuse you.
I hope this will solve your query, if in case yo are still having issues, do tell me.
Concerned, Nooh
Aug 12, 2010 | HP Officejet 6500 Wireless All-in-One...
How do I change time on Kadio clock 3805, thanks ?
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
I hope it will help you..
May 15, 2010 | Watches
Program date and time on the microlife bp monitor
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Jun 08, 2009 | Microlife 3MQ1 Blood Pressure Monitor
I am trying to set time and date on a calculator
OK, I bought one over the weekend just for chuckles. I figured it out.
On the top of the calculator there is a key that shows a little clock. Punch it once and the date appears...like 01-01-2000 or somesuch. Press it again and the time shows up..
Hold the time set key (=) down for a second until the first zero starts to flash. All you have to do is start punching in the time. When you are done press the time set key again. Voila!
Punch the key with the little clock again and the date shows up. Hold down the time set key for a second like explained above until it starts flashing. Enter the date with the key pad numbers. Done!
I couldn't figure this out either till I looked above each key (didn't notice what it said). Anyway, look real close.
Hope it works out for all and everyone finds this solution...
CMHIMG
Mar 04, 2009 | Canon P200-DHIII Calculator
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
Nokia 6600 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
