Question about HP LaserJet 4100n Printer
H.P laserjet 4100 series.
My printer is working perfectly except that every time I want to print it tells me to put an envalope into tray #1 I went through the settings to try and figure out what the problem is but all that happens is it gives me the option of printing from tray #2 wich is the rite tray. how do I solve this problem. please help.
  • malps Dec 14, 2007
    Hi
    I have a similar problem with my HP 4100n and have just tried these solutions including the cold re-set. Still when I try to print I am getting the message...tray 1 load plain letter.I cannot get it to automatically take from tray 2 or 3.Have got all my printer settings on Pc set as suggested.
    orange light keeps flashing too. Any ideas? i wlould be most grateful!
    Thanks
    Linda
  • HP Master
  • 1,113 Answers
Also..Remove paper tray and Squeeze the blue tab located on the right side of the all paper trays and move it to the correct position based on the paper size required
Posted on Dec 23, 2007
    Problem Solver:
  • 17 Answers
Printout a copy of your printer configuration. Press the right-side of the MENU button once, then the right-side of the ITEM button twice, and press the SELECT button once. This will print out a configuration page. In the lower right part of the information on this page, it will give you stats on the Paper Trays and Options. Standard settings on these should be "Default Paper Size: LETTER, Tray 2 (LETTER). If either of these says anything different, I would do a cold-reset on the printer to reset it to factory defaults. If you have a network card installed, you need to pull it out before doing this. To do a cold reset, turn the printer off, then hold down the GO button and turn the printer on. Wait about 5 seconds, then release the GO button. Also, you need to check your print setup on your PC. I am assuming you have a WindowsXP machine. Click START, SETTINGS, PRINTERS&FAXES. Right-click your printer icon and select PROPERTIES. Click the PRINTING PREFERENCES button at the bottom. Click the PAPER tab. Check the boxes at lower left. "Size is should be Letter", "Source is & Type is should both be Auto Select". Click OK, click OK, and exit the Printers Window. Lastly, I would make sure that you have Letter size selected from the application you are trying to print from. Hope this helps.
Posted on Feb 27, 2007
Why my HP LJ 4100 is always taking envelopes from tray 1, even when I try to print from tray 2?
Check your feed rollers in tray 2. Sounds like they are worn and the paper cannot be pulled from tray 2 so it goes to tray 1
Sep 20, 2013 | HP LaserJet 4050 Printer
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
Hi there! Printer: HP Laserjet 4100 Problem: does not want to make both side printing. Used settings: Printer Properties->Finishing->Print on Both Sides (click) Thanks for your...
To automatically duplex, you need the optional duplexing mechanism.
If you don't have this, your only option is to print the odd pages first, put the papers back in the tray, then print the even pages.
When you put the pages back into the paper tray, make sure they are print side up.
Try with a 5 or 6 page document first to be sure you get the orientation right.
If you HAVE the optional duplexing unit (which sticks out the front just above the main paper tray) then post a reply here and I'll try to help you further.
99% of the people that own this unit do NOT have the optional duplexer!
Mar 12, 2011 | HP LaserJet 4100 Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
LaserJet 4350 Printer: 49.2f02 service error on hp 4100 printer...
Turn the printer off for a few minutes and then back on. If that does not fix the problem, try to have the print queue cleared and tray again. Most of the time it's a PDF file that causes this problem. If that does not fix it, it may need a new Jetdirect card.
May 16, 2010 | HP LaserJet 4350 Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Settings in HP Printer LJ 4100.
Hope this helps.
Mar 23, 2009 | HP LaserJet 4100n Printer
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
kw7157@yahoo.co.uk
Mar 20, 2009 | HP LaserJet 4100 Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
HP LaserJet 4100n Printer Logo
876 people viewed this question
Clive
Clive
