Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Can ixus700 upgrade to use 4gb memory card?
Can the canon ixus700 upgraded to use 4gb memory card?
  • 2,039 Answers
The ixus 700 is only specified to be compatible with SD memory cards (and MMC cards). The protocol for SD cards only covers up to 2MB. Cards of higher capacity are the SDHC (high capacity) protocol, but this protocol did not exist when the ixus 700 was introduced. As far as I can tell, there is no way to upgrade to be compatible with the newer protocol.
Posted on Dec 09, 2008
How can i convert 4GB pendrive to 8GB ...?
There is no way of doing this. If your pen drive is 4GB, that means it has only 4GB of memory chips in it. The only way to get 8GB is to buy an 8GB drive. Do not buy an upgraded (to 8GB) one, as they are lower memory ones that have had the firmware tinkered with to show 8GB, when the actual memory capacity is far less.
18.January.2015
Jan 18, 2015 | SanDisk Electronics - Others
Can a 16 mb sd card of a canon zr600 be upgraded to 2gb?
Sure. Simply use a larger card. The ZR600 will work with any SD card. Be careful to get an SD card and not an SDHC card. SD cards go up to 2GB (2000MB) in size. SDHC cards look identical but start at 4GB but will not work with this camera.
Apr 10, 2012 | Canon ZR600 Mini DV Digital Camcorder
Hello I currently have a 2 GB memory card in my canon SD 1000, camera i want to upgrade to 4GB memory card, what is the best brand or type? Will 4GB SDHC memory card work with my canon camera? ...
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
Mar 26, 2011 | HP PhotoSmart 7350 InkJet Printer
Hi, I have Canon IXY Digital PC1101, showing error for 4GB SD Memory, where as the same is working in laptop. If i put 256MB SD in camera it's working.. do i need to do any firmware upgrade to camera to...
The PC1101 uses SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. Since this is a hardware incompatibility, no amount of firmware changes will make it work. You need to stay with SD cards, 2GB and smaller.
Jan 05, 2011 | Canon IXY 1000 Digital Camera
What is the maximum memory I can install
Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jul 08, 2010 | Acer Aspire 5630 Notebook
4GB card incompatible?
I've come across many people who say their card isn't locked only to find that the slide switch on the side of the card is indeed in the locked position. Check yours.
Jan 15, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Does Nvidia Quadro FX3400 support 4gb of RAM? My
If there would be no increase in performance, no need to do upgrade. try to check the performance of your computer using BENCHMARK softwares.
Oct 18, 2009 | HP Compaq NVIDIA Quadro FX3400, (256 MB)...
I want to upgrade the memory card of my Canon PowerShot A570is. What memory card should I buy? The last that I had was a SanDisk 1.0 GB.
The camera supports SDHC memory cards, so any SDHC card should work.  If you shoot video the cards with the faster write speeds are better.  The SanDisk 4GB or 8GB cards should work well.
Apr 26, 2009 | Canon Cameras
Sandisk memory card
Has this card EVER worked with your camera? Since you didn't mention the model number of the Canon, it's possible that you have a compatiblity issue here. Most 4GB SD cards these days are actually SDHC cards, which store memory differently (in sectors, like a hard disc drive, rather than bytes, like your main memory). All SDHC compatible cameras also support SD cards, but cameras sold before the SDHC standard was created will not support SDHC memory cards.
There's a chance that Canon has a firmware upgrade to solve this. You would have to look on the Canon USA web site for this, based on the model number of your camera.
Jan 20, 2008 | Cameras
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
295 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
