Question about Dryers
Electrical fan connection
I have a light swith to connect to a ligth switch the light swith has to cables switch live and live. my fan has three wire L L1 N, this need to go through a fuse spur how do I connect this also should the fuse spur be earthed as when I connect live to fuse spur neutral is live to
  • Anonymous Mar 17, 2014
    how to wire a fused spur
  • 417 Answers
Firstly, yes the fused spur should be earthed. You should wire from the fused spur to the fan L,N & E.
Your light switch should be in line on your light live supply wire.
If you wish to use the light switch to turn on the light and fan at the same time you should also run a live switch wire to the fan L1.
This should FixYa.
Please remember to rate this solution.
Posted on Dec 09, 2008
How do I wire 2 fans in 1 bathroom
If you want both fans to run at the same time it is simple once the fan installation is complete. First turn the power OFF at the electrical panel. Run a piece of 2 wire (with ground) romex (cable) from the exiting fan to the new one. Then connect all the black wires together, all the white wires together and all the ground wires together in each fan. Connect the ground to the metal housing on the new fan. (Three different connections in each fan). Make sure to use the proper cable connectors and wire nuts. Turn the power back on and the existing switch should turn on both fans. If you have a red wire in the original fan it is a little more detailed. Post again if this is the case.
Feb 17, 2016 | Electrical Supplies
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
I have a Westinhouse 3-way fan light switch item #7052. What do the numbers 1 and 2 and the letter L in the back of the swith mean? There seem to be a realy box which says that has yellow and purpel...
Good afternoon. You did not happen to take a picture before you pulled the old switch out did you?
I'm going to guess that you mean the three speed motor control switch.
"L" Typically this is the "Line" side and it goes to the black connecter. Since I cannot see what you have, the "1" and "2" are the other speeds for the fan motor.
Nov 21, 2017 | Westinghouse Electric Ceiling Fan 3-way...
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
My girlfriend has a leviton illumatech IP106 that keeps "not working". after a number of months. It is operarting a standard dining room 6 light chandelier. A couple of her friends have replaced this in...
As a general rule for timers and dimmers:
The Black dimmer wire connects to black hot wire coming from breaker (122V line)
The red dimmer wire connects to Load (wire going to chandelier)
The wall red wire that is capped could be a couple different things. a) It could go to a second switch that was used to control the chandelier. b) it could be another wire that goes to same ceiling box as chandelier to be used to control a fan, except you don't have a fan. In the second case, if you install a fan with a light, you could control fan and light separately.
The green is a ground wire that connects to bare copper wire in box. The bare copper connect back to main breaker box on the Neutral busbar.
White wires that are twisted together inside your light switch box also connect back to to main breaker box on the Neutral busbar.
The ground wire and neutral are a redundant safety system to protect you from electrical devices and appliances that have 'shorted'
The black hot wire connects back to the circuit breaker.
For example, each circuit breaker controls one area of household lighting. The black white and copper wires leave breaker box in a single romex cable. The romex travels to a junction box in the area where the lights are located. The junction box is usually a switch box or a ceiling box. From the junction box, the romex travels to each other switch, light and receptacle box in the area. So each box has 1 hot and 1 neutral and 1 ground that is connected in a line that leads back to breaker box.
Here's a couple pages that make home wiring easier to understand:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Install-owb.html
Oct 15, 2010 | Leviton Decora Light Dimmer Switch
II have a switch and dimmer and the three wires from fan and light, no instructions how install it.
You will have power coming in through a black wire and white wire on the cable set that does not go out to your fan. The black will connect to your switch to power it. Then there will be two other terminals on your switch one for your fan and one for your light. The red and black that go out to your fan and light are connected to these two terminals. The whites get connected together. If you mix the red and black up and the switches are controlling the the wrong things, simply switch the black and red wires. (Note: If by three wires to your fan you meant black, white and bare copper this dual switch cannot be used, as bare copper is simply a ground wire and cannot be used as a constant electrical conductor.)
Jun 05, 2010 | AMS Lutron S2-LFSQ Skylark Dual...
Am fitting new ceiling lights have 1 live 1 neutral 1 earth wire to connect . the ceiling connection has 2 live & 2 neutral wires as well as the connecting wires what do i do with spare wires do i wrap...
the 2 live wires are 1 for lights,1 for fan,keep them separate if you want control from 2 wall operated switches,if you only want control from the switches on the fan you can tie these together,as for the2 neutral wires they can be tied together at the fan box,and the 1 earth wire goes to the metallic surface ground screw on the unit
Feb 09, 2010 | Gb Electrical 100 Amp GE Load Center
Need wiring diagram live cable from switch to pull switch then to
If I am understanding you correctly .,. then like this ..
Please Vote !!
Jan 12, 2010 | Solar 2-wire Pull Chain Light Switch For...
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
Dryers Logo
336 people viewed this question
Top Dryers Experts
