KONICA 3135 COPIER
I'M GETTING A MESSAGE SAYING: PLEASE CALL SERVICE AND REPORT CODE 36-2
  • 42 Answers
This is a fuser abnormality code.To reset code:Holding down "2"&"5" while turning on copier.Press P-4-7-P on the key pad.(1,4,5,or 6 will be displayed on the copy quantity indicator).Press the 0 key to change the indication to a zero.Press the start/print key to inter the new data.Power the machine OFF the ON to exit the 25 mode.If the F code reoccurs after powering up the copier will need either a lamp or thermal fuse in the fuser unit.
Posted on Dec 11, 2008
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konica 3135 autofeeder F60 error
this error code means the interlock switch ms301 has failed or it could be the radf control board or the harness for ms301 it is almost impossible to find parts for these machines now. they are on the konica obsolete list sorry and good luck
Dec 03, 2009 | Office Equipment & Supplies
How do you fix a F 86 error code on a konica 3135 copier?
This error code not exist .Please tell me precise your problems and your error code.
Dec 02, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 error code f 43 ( exposure lamp)
The exposure lamp is located in the scanning area beneath the glass. If you choose to do it yourself you can purchase a lamp here
https://www.interlight.biz/light-bulb/252254045&ID=FROOGLE-US
You can get the manual here
http://www.service-manual.net
Be sure to follow the steps closely it is easy to do more damage than good in that area if you try to wing it. Good Luck
Apr 20, 2009 | Toshiba E-Studio 161 Copier
Konica 3135 Copier Code F 36
Well, I'm sorry to say that you're going to need a tech for this problem. You have a fuser problem...either a blown fuse, heater lamp, thermistor, or something...whatever the cause, the fuser is not heating up. And the code can only be reset within service mode, once the problem is repaired.
Feb 25, 2009 | Konica Minolta Office Equipment & Supplies
Konica 3135 Copier
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Feb 25, 2009 | Office Equipment & Supplies
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Konica 7020 copier
35-9 is a low temperature error in the fuser.If the fuser has a problem it will not make a copy period.Sorry. Mrbonz
Jul 20, 2008 | Office Equipment & Supplies
Copier: Konica 3135 p.81 Insert key counter
you have to be in the service mode.To be exact the 25 Mode.To enter turn power off,Hold down the "2"&"5"keys while turning power on.Then press the "p"key.Change the number you see to 57. So now you should see P57in the display.Then change the value from 1 to 0,then press Print.That holds it in memory.Then just turn off and back on.
Oct 16, 2007 | Office Equipment & Supplies
109 people viewed this question
jasbo
jasbo
