Question about Cosco Alpha Omega Elite 5-Point 22-155
Where do i attatch the straps in the back? - Cosco Alpha Omega Elite 5-Point 22-155
    Scholar:
  • 90 Answers
The straps that are attached to the seat are supposed to be used with the LATCH system that has been built into newer cars. You use the straps on the carseat to hook into metal loops under the seat instead of using the seat belt. If you aren't sure whether you have the latch system in your car or not, consult your owners manual or call a dealership and they should be able to tell you.
Posted on Jan 02, 2009
Where to attatch back straps?
Please contact Graco directly for assistance
Jun 01, 2014 | Graco Nautilus 3-in 1 Car Seat
Where will i find the ground wire on my 1999 dodge ram 2wd? My truck will not start just wh.ines over
ground straps usually attatch to firewall, and frame to the block, most veh have atleast 2 start by looking at frame and firewall for broken ******** either. however you can add one by simply finding a bolt on either frame or firewall, and attatch to and from bolt on block make sure the bolts don't hv plastic or rubber though so it will make good contact. (however if it's just whining, that sounds like the bendix is bad in the starter) have you tried replacing the starter?
Sep 08, 2012 | 1999 Dodge Ram
How do you put the straps through the coseytoes
In the cosy toes you should have little slits for all of the straps to go through, if you unclip all of the straps so they are all seperate then place the cosytoes onto the seat, the straps should slide through fuss free, once you have pulled them through the slits just attatch them all back together and you should be ready to go
Hope this helps
Mar 01, 2011 | Quinny Buzz Three Wheel Stroller
How do I attach a jump ring to the sandisk so I can attach a strap? Where can I get a jump ring small enough and where do I get a strap?
Hi, if you go into any phone shop and buy one of their straps they come with a cord that you loop through the hole and back on itself and this cant then come undone by mistake, its like a nylon thread that you feed through the hole and then put the end through the whole and pull tight you then just clip the strap onto the clip on the loop part, this is very secure and strong as its made to hold the weight of a mobile phone worn around the neck, how ever if you dont want the long strap you can just use the small loop part to attatch it to a key ring or similar.
I know you may be a bit confused but if you go into a phone shop and take the usb drive with you you will see exactly what i mean, these straps also cost near nothing so you cant really lose.
go into any small phone shop or market stall that sells phone accessories and you will see the neck straps im going on about you have the long neck strap part and this attatches to a small nylon loop that you can feed through the tiny hole on the flash drive
hope fully you understand what im saying.
let me know if you have any problems
Jul 06, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Change the seat cover on quinny buzz
Hi the seat is attatched to the frame with a hard edging.
1st; take it off the bootom which is velco
2nd; slide the seat cover out of the frame from bottom to top, this is a tricky
3rd; The top of the seat cover is attatched the same way but sideways, you need to undo the straps from the top then feed them through the holes in the cover.
4th; Attatch new seat cover the same way but in reverse.
May 01, 2010 | Quinny ZAPP Stroller
How do i fit the footmuff on my quinny buzz pram?
Hi, to fit the footmuff, you need to undo the straps which can be done right at the top shoulder bit. Once this done you then thread the harness through the side holes on each side of the footmuff, then through the top hole & re-attatch harness to pushchair. All that is left to do it push the **** strap though the bottom of the footmuff. Hope this is of help to you. Regards Marie
Apr 27, 2010 | Quinny Buzz Three Wheel Stroller
How do i change the straps up a hole on the Quinny Buzz?
Hi put finger in the hole & pull it out a bit more you can the unclip it, do the same again with the top hole you should be able to feel more webbing pull that out & re-attatch to that.
Apr 16, 2010 | Quinny Buzz Three Wheel Stroller
The hook where the camera strap attatches broke, is there a way to replace it?
Yes, Your camera cover is covered under the same warranty as your camera, so remember your serial number when calling:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 08, 2010 | Kodak EasyShare M853 Digital Camera
I took the cover off of my daughters graco comfort sport car seat to wash it and now I can't figure out how to attatch the straps
Look for a Certified Child Passenger Safety technician in your area, so he or she can help you to put it back together. Go to this link http://www.safekids.org/certification/os.html click on find a Technician.
G.A.
Jul 20, 2009 | Graco ComfortSport Convertible Car Seat -...
Cosco booster seat (Summit)
turn the seat so you are looking at the bottom, insert the strap- one end on each side- turn the seat in an upright possition facing you, put the buckle pieces on appropriate side, attatch the center piece- at the chest- insert the strap into the appropriate slot- the adjustments- now turn the seat so you are looking at the rear of it, attatch the metal retainer.
Nov 25, 2008 | Cosco High Back Booster 22-200 /22-207
Cosco Alpha Omega Elite 5-Point 22-155 Logo
118 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
