Question about Kitchen Ranges
Model # FGF337ECD i was using one top burner sunday and my carbon menoxide alarm went off. after the fourth time i had the fire dept. and gas company show up. they pinpointed the stove as the culprit. is it a bad unit? can it be fixed? what do i do? thanks
  • 171 Answers
It 's very easy to fix, the oxygen vents need to be open on that burner, they are located as the burner meets the valve that supplies gas to it.
Posted on Dec 10, 2008
4 beeps with pauses for 2 year old carbon monoxide detector
I'm pretty sure that indicates an alarm. The pattern is referred to as "temporal 4" which is the alarm pattern for CO. Either your device is in a bad place or there is an intermittent CO leak which is exceeding the ppm (parts per million) threshold for a given time period. The instructions for the device will tell you what that number is. If you have more than one of these, I would try swapping them to determine if the problen is with the device or the location. Good luck!
Apr 24, 2015 | Kidde Kiddie - Nighthawk Kn-cob-lcb-a Fire...
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
Carrier Weathermaker 8000 Furnace Flame Surges on start up
The fuel is controlled by the gas valve, the amount of gas is controlled by the regulator, I would verify that the inlet gas pressure is within the limits of the gas valve/regulator. The surging is likely the fault of the regulator and could be as simple as a spec of something in the orifice that allows gas pressure on the top of the gas regulator diaphragm. With the surge there must be an accompanied change in gas pressure at the gas valve outlet to the burners, use a "U" bend manometer to verify as they are the most simple and accurate and react instantly with no "averaging" software to wonder about.
Mar 16, 2017 | Carrier Heating & Cooling
The detector has gone off two times within the last week. The detector reads "GAS" when it goes off. THe number the first time was 199 and yesterday is was 235. The first time I got out of the...
Propane is heavier than air so if the detector is mounted ABOVE the appliances that use it (or any tubing that brings the propane into the house) it (the propane) will NOT be detected, even if there is a leak. That said, the PRODUCTS OF COMBUSTION of a propane appliance will still contain carbon monoxide (CO) which is lighter than air and will be detected by a properly installed detector. If you continue to get alarms and readings that differ from each other, along with no error codes on the display, it sounds like the detector is really detecting something. If the fire department cannot identify a source, try calling the Kidde "Hotline" at 1-800-880-6788 and ask if they can recommend another agency in your area to check your premises. I don't think these units detect Radon but am not sure. If your dwelling is of relatively new construction, the problem can be complicated by the fact that there is less outside air infiltration to disperse any build-up of gas/radon/CO/etc. than is typical in older construction. *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera"The problem can always be solved with the materials in the room." -My college Physics Lab
Dec 08, 2010 | Kidde Nighthawk Combo Gas/co Detector
Nighthawk carbon monoxide alarm model number KN-COPP-3 err beeping every 25-30 seconds, I replaced battery they still beep. They say to seek users guide, which can't be found. It seems to have started...
1. Change batteries.
2. Clean it.
3. Swap it with another location if you can.
If it still does not work properly consult the local fire dept. for free.
You may have to take it in repairs if all fails.
Nov 08, 2010 | Kidde Nighthawk Combo Gas/co Detector
Have the oven burner gas stove emits too much carbon dioxsid what is the solution: Change the burner? Or give a pretty clean? Thanks
This is an extremely dangerous problem that should not occur. There has been a product recall for models of electrolux and kenmore's manufactured in Canada, so you should check the US Consumer products safety commission.
You should not use your oven for heat because it can also use up all the oxygen in a well insulated environment. You should never cover the bottom of the oven with foil. It blocks vents and causes Carbon monoxide to buildup.
If that is not the case, you should really have a qualified technician clean and tune the oven, because if you are right and your oven is emitting enough carbon monoxide to trigger an alarm, you can wind up dead.
Tuning can involve adjusting gas flow and checking regulators. If you still want to attempt a solution, check the top and bottom burners. Make sure the are in good visual shape and use a small pipe cleaner, paper clip or some other wire that will not break off inside the jet holes.
Clean the oven and check your manual to make sure that it does not require a vent.
Fire companies will often help out with finding the source of carbon monoxide, but they do not want people to air out or clean the offending area or appliance. Please take care, and thank you for your question.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Oven smells like gas when on
If the oven is new and has never been used, it should be cured before using. There is a curing your oven page in all manuals before use. You have to wash and burn off all the chemicals used in making the thing. Are u sure it sets off the smoke alarm and not the carbon monoxide alarm. Be careful some alarms are equipped with both now a days and people cant tell the difference. Get your gas company there to check it. Carbon monoxide is undetectable to the nose and is deadly so please be very careful! If there is smoke and u have cured ur oven then there maybe some old food on the burner, remove the bottom plate and check. If there is no smoke and no food on the burner then u need to change ur ignitor. It maybe old, cracked or both. Typical repair cost on high end range is 300 - 400 for 1 ignitor. Good luck. And I urge u to see if it is Carbon Monoxide!
Sep 04, 2009 | Hotpoint RGB745 Gas Kitchen Range
Carbon monoxide leak from back burner on stove
You need to get the control valve for that burner replaced. It's at the front of the stove.
Jan 27, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Kitchen Aid Oven and Carbon Monoxide Leak
If you have Propane than any range will have to be properly converted to propane they are made for natural gas. Other than that gas ovens do emit quite a large amount of CO and new homes are built very air tight and any good CO detector may sense this. If you have a vent hood or hood/mwave combo and its vent is actually ran to the exterior it should aid in venting that CO. This is why the new dual fuel (gas cooktop, elec oven) are so popular. Hope this helps...
Jan 12, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen Ranges Logo
167 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
