Question about Indesit W 123 Front Load Washer
Broken handle i have got new handle kit for iindesit wd12x but i am having problem getting door to stay closed after installing it. can u post diagramme of how it goes together.
Patience and an empty house got the job done try it yourself throw wife and kids out it works a treat
Posted on Dec 13, 2008
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
Oct 31, 2015 | Washing Machines
2008 chevrolet interior door handle repairs
There is a repair kit for you truck. The part that is broken is the metal piece. If you go through GM you have to buy a brand new interior door trim panel because the door handle part is attached to it. Otherwise I found a company that offers a repair kit that just repairs the broken part. Plus is cheaper then buy a whole interior door trim part. Total Automotive GM Truck SUV Interior Door Handle Repair Kits
Apr 25, 2012 | 2008 Chevrolet Silverado 1500 2WD
I removed door panel to install speakers now the door wont close
You need to make sure the panel is on perfect. If it is a little off, it will catch the ends. Is the inner panel catching the door? If you added bigger speakers, it may catch on the inner part of the door, closet to the speakers.
Feb 18, 2011 | 2002 Dodge Durango
I have a 2 year old indesit wd12x been fine
could be the catch has broken you may have to force it open and new complete door is about £25.00
Mar 01, 2010 | Washing Machines
Hotpoint tdc 30 door catch will not push into door switch when I close door, have taken switch out and it fits into catch manually but not when it is installed so door will not close to activate drying
I would say that the problem is due to the door handle spring being weak or broken.
Purchase a door handle kit, and it should solve the problem, if it does not, then you need a new door switch.
Hope this helps with your problem.
Dec 09, 2009 | Hotpoint NVL333EY Electric Dryer
Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Jul 07, 2009 | Indesit W 123 Front Load Washer
The door on my indesit wd12x washer dryer will not open. The machine has finished the cycle and was on the tumble dry mode when it finished. The handle feels loose like a spring has sprung. Any...
slide in a piece of string around the door. if lock is on the right, pull round the door til the pieces of string are at left of the door and pull left quite firmly.
Oct 17, 2008 | Washing Machines
Broken door handle...
I have the same problem and I have a makeshift solution which I was able to do in 45 minutes and total cost was less than $1.
Step 1: Remove door from machine.
Step 2: Disassemble door with the two plastic donut shells. This means removing 6 or so flathead screws. Take care to note alignment of glass parts because they aren't perfect circles and only fit one way.
Step 3: Pull out pin that threads the spring and broken plastic handle remnant and metal latch piece.
Step 4: Discard broken plastic and replace the rest of the apparatus. The metal latch can move up and down, but that's ok.
Step 5: Purchase a paint-can opener:
http://www.istockphoto.com/file_thumbview_approve/525566/2/istockphoto_525566_opener_for_paint_can.jpg
Step 6: Re-attach door.
Step 7: You can use the paint-can opener to the right of the latch to lever-open and lever close the latch in order to open and close the door.
Cheap, easy. Not pretty at all. Definitely something your friends would make fun of you for doing, but it saves you $1,000 of a new machine, in this economy.
Jan 19, 2008 | Equator EZ 3612 CEE Front Load...
Indesit W 123 Front Load Washer Logo
237 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
