Question about Panasonic Toughbook 50 Notebook
Panasonic cf-50 laptop in Iraq
Monitor displays Red, green and blue colors while booting up, but after windows starts the display is fine. So when I try to do maintenance on this laptop, not able to use the display. Can get into setup and display is ok, and also in windows, but not when I boot from cd. Can someone please help me?
  • Anonymous Dec 09, 2008
    plz how i can make updat for my bios ?and how i can get bios for panasonic cf-50
    Problem Solver:
  • 12 Answers
There are a few possibilities here... It sounds like a Graphics Card problem. It may well be an issue on a certain resolution mode. Try changing the modes in windows control panel to see if you can replicate the problem. If you cant then it will likely be the Bios that needs an upgrade (Flash)
There is also a small chance that the LCD Cable needs to be reseated. One other tip is to plug in an external monitor and then check to see if that happens on the external monitor. If it only happens on the LCD then there wont be an issue with the graphics card and then leans towards a LCD Screen or cable problem. More diagnostics at: www.powerjackrepair.com
Posted on Dec 09, 2008
External display video monitor
On Page 10 of the Operating Instruction Manual
for the Panasonic Toughbook CF29, it shows
the "External Display Port" or VGA Connector
located on the back side with the cover closed.
This port is located approximately in the center
of the back side, just to the right of the
port replicator port and may be colored "BLUE".
The manual can be found here:
ftp://ftp.panasonic.com/computer/om/cf-29htlgzbm_en_om.pdf
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Feb 02, 2014 | Panasonic Toughbook CF-29 Notebook
Video red green blue black white
1) There's a problem with your computer or Display.
You'll need to go to a computer specialist, he/she can fix that.
Jan 09, 2013 | HEWLETT-PACKARD HP EliteBook 8540p WH253UA...
Hp dv6833 laptop boots up fine but after that it display complete white screen then after sometime Blue...then Red ...then Green etc. this pattern repeats in a cycle.
Hi, have you tried isolating by using external monitor? if you use external monitor and it displays then something wrong with your built in video card.
Jun 16, 2011 | HP Pavilion dv6833us Core 2 Duo T5550...
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Samsung x10 don't boot to windows,
plug in a monitor in the side of the laptop if it shows up then the lcd is bad. Also try and reset the memory by pulling it out and then put it back in if not in all the wall nothing will appear on the LCD.
Jan 11, 2010 | Computers & Internet
I have a dell e1505 laptop you turn it on it flickers to dell for about a 1/2 second then goes virtually black but if you look real close the screen is there.you can still hear it, i hook it to a exteral...
hi there !
-if you switch the computer on and it boots up and you hear the windows sound, this could be a possible video problem or motherboard problem
-run the diags on the LCD, while the computer is off, press and hold "D" then press power button at the same time, if you see the colors red blue green without any problems then it is a motherboard or video card problem
-another method to run the test is while the computer is off; preess and hold Fn then press power button, let the test run; when you see the question were colour bars displayed, press N, if you see the colors red blue and green without any problem then it is a motherboard problem or video card; otherwise it is an LCD problem
-to toggle display on the external monitor press Fn then F8
cheers !
Oct 20, 2009 | Dell Inspiron E1505 Notebook
Color Display on Panasonic Toughbook CF-28 is dull
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 01, 2009 | Panasonic Toughbook 28 Notebook
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
LCD Screen Problem on booting
Ok, when connecting to another monitor, be sure to use the Function Key, and press the appropriate F Key to enable an external monitor. Without doing this, you will never see an external picture.
If that picture is fine, then yes, you need to think about your video card, and I would start with updating the driver.
Erik.
May 11, 2008 | Dell Precision M60 Notebook
Panasonic Toughbook 50 Notebook Logo
236 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
