Question about Kalimar V-20S VIDEO TRIPOD
Tripod I am missing the part that screws into the camera and then attaches to the tripod. Where can I purchase or how to fix.
  • 4 more comments
  • Anonymous Nov 30, 2007
    I lost the screw in piece for the camera that attaches to the tripod.
  • albert2214 Dec 14, 2007
    I am also missing the screw plate that attaches the camera to the tripod. I have a Kalimar 3-CLB. Is there any place to purchase this part?
  • Glennxti Feb 20, 2008
    Has any one found the solution to the missing part for the Kalimar 3-CLB? I'm in the same situation as the rest of you!! Let me know if you find out where to get one! glenn@4wheelers,.com
    Thanks
  • boaterhead Mar 16, 2008
    missing plate to attach camera to tripod
  • Anonymous May 27, 2008
    Same problem. No shoe. Has anyone found a suitable substitute?
  • Anonymous Mar 12, 2014
    No screw in place for the camera to attach. The top of the tripod has a tan plastic head with curves.
I have the same problem. Can't believe I can't find the shoe, but the tripod is worthless without it. If you get an answer, please email it to cheimerman@comcast.net. I'd GREATLY appreciate it!
Posted on Oct 02, 2007
SOURCE:
My wife bought a Kalimar Pro-Tech V-80S used for my Canon Rebel Digital Camera. The base that the camera sits on, where there is usually a screw to attach the camera seems to be missing a slide in base to...
I have the same issue as Mike, above - same tripod, lost the platform for the camera. Anyone have a spare camera platform for this particular tripod they can sell?
Oct 06, 2011 | Kalimar V-20S VIDEO TRIPOD
I need to purchase screw that attaches scope to window mount on a 78-4405
The mount has a 1/4-20 screw that fits most camera equipment. If you have the scope (spotting scope) it should have that hole in the bottom of the mounting ring. If the screw is missing from the window mount then most 1/4-20 tripod screws will work or you may substitute a cap screw and flat washer, to work with an Allen wrench for tightening.
Feb 07, 2011 | Bushnell 784405 Tripod
DONT KNOW HOW CAMERA GOES ON TRIPOD WILL ANY CAMERA WORK ON IT OR DOES JUST CERTAIN ONES WORK ON IT IT IS A DYNEX 60 " DIGITAL TRIPOD
It is usually obvious where the camera goes, so I am pretty sure that what you have is a tripod with a quick release plate that doesn't have the quick release plate fitted. This is very common when you buy a tripod second-hand. The quick release plates get attached to a camera and people forget to reunite them with the tripod before disposing of it.
If you bought the tripod new, then look in the packaging for a plate with a screw to attach to the normal camera tripod screw in socket. There ought to be more than one. The screw is standard throughout the world, except maybe Germany that used to use a different size. Any camera you have will have this socket on the bottom, a threaded hole about a quarter inch (5 or 6mm) in diameter. The plate will be a design peculiar to this make of tripod, and if you lose it or don't have it you will be unlikely to get another.
Jan 25, 2011 | Dynex 60" Universal Tripod
How to put a camera on it
If it's a quick release tripod you need to remove the quick release plate (Usually a release lever to the side of the top of the tripod) and then fasten the plate securely to the camera and then the plate to the tripod. Older non-quick-release tripods have a knurled screw located below the flat area where the camera is attached. If the screw is missing, get a relacement from your local hardware store - 1/4" -20. (Find a way to keep the new one from getting lost.)
Jun 12, 2010 | Ambico 67" TRIPOD
How do I attach the camera to the tripod?
Check the back of the camera to check if there is a hole with thread.
The top part of the tripod usually comes out. Screw the top part of the tripod to the camera and after that attach it back to the tripod.
If you need further assistance, just leave a comment. Cheers
May 02, 2010 | Sunpak 8001UT Tripod
I bought a used camera tripod that does not fit my camera
Your tripod is a K-Mart brand item and it will fit any camera but it's clearly missing the quick-release foot which most tripods have these days. This part screws to the bottom of the camera and enables the camera to be quickly attached and removed from the tripod.
Unfortunately there is no standard foot shared between manufacturers and most tripod manufacturers don't even have a standard design foot which fits all models in their range.
You can still order a replacement foot from:-
http://tripodquickrelease.com/Focal_Quick_Releases.htm
But at US$18.99 it may be cheaper to buy a new tripod!
I hope that you appreciate the time which I've taken to research and answer your question and ask only that you return the favour by rating my answer.
Aug 11, 2009 | Sanford Traveler Tripod
Adaptor for Samosonite Tripod
not sure about the brand tripod but all good ones have a 1/4 standard screw that has blank shoulder so it spins freely yet stays in place there..see your local pro camera store for a 'camera mounting screw'..... or order from samy's camera online
Dec 08, 2008 | Samsonite Case & Tripod Kit for Digital...
Kalimar pe-8 tripod
It is a standered size and thread found on all cameras. Ace is the place
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 01, 2006 | Kalimar V-20S VIDEO TRIPOD
Photography Logo
361 people viewed this question
Top Kalimar Photography Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Kalimar Photography Expert? Answer questions, earn points and help others
