Question about Brother MFC 7420 All-In-One Laser Printer
I can receive fax but can't sent it out - Brother MFC 7420 All-In-One Laser Printer
  • 3 more comments
  • easy_transla Dec 09, 2008
    i can dial and have dialtone when i hear fax sound i put start and after that phone it hangup and report errer result...
  • easy_transla Dec 10, 2008
    yes it's every time i try to sent fax out,
    "Area code if required, a "9" " yes it is, but office refer the system fine, other machine can sent fax out.
    The machine print a fax report with
    date,time...
    fax on/name...
    duration...
    page(s)...
    result errer
    mode statndard
    that's all report
    sorry for english ...i'm poor
  • May 11, 2010
    Is this happening on every fax you try to send? Are you dialing all the required digits of the fax number when you call? (Area code if required, a "9" or whatever you need for an outside line if this is on an office phone system, that kind of thing.) The machine should print a fax report with a little more explanation of the error. What does it say went wrong?
  • May 11, 2010
    What happens when you try? No dialtone? Original doesn't feed? Error messages? Need some more information.
    Champion:
  • 320 Answers
Sounds like a phone line problem or may be the phone board is bad???
Posted on Feb 16, 2009
How do you find fax log for sent faxes on Dell 962 All-in-One
Only faxes sent and received by Fax Console can be seen by Fax Console. View the Status of a Fax Using Fax Console or Fax Service Management
  1. Click Start All Programs (or Programs) Accessories Communications Fax.
  2. Click Fax Console or Fax Management Services.
  3. The following folders appear:
    • Incoming - faxes currently being received
    • Inbox - faxes that have been received
    • Outbox - faxes scheduled to be sent
    • Sent Items - faxes successfully sent
  4. Click the folder of your choice.
  5. Click the fax in the right pane for which you want to view the status, and then click Preferences or Properties.
  6. Click the General tab and view the Status line.
  7. Click Close when you are finished
Mar 05, 2011 | Dell 962 Photo All-In-One InkJet Printer
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Received confirmation
Sent confirmation reports are available within the fax machine.
Theoretically if the fax has been successfully sent, it should be successfully received on the other end as well.
But unfortunately there is no confirmation for successful receipts, unless you are using IP based fax transfer.
Mar 31, 2010 | Brother IntelliFAX 560 Plain Paper Fax
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Restoring sent and received faxes to fax logs
That's not the way to backup your logs. You copied only the fax images, and not the logs to go with them. This is a common error that is made quite often. Unless you have the original log structure, your data (logs) that link to the actual fax images (fxds, fxrs, etc.) are lost.
Troubleshooting WinFax suggestion:
http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=412
Jan 02, 2009 | Symantec WinFax Pro for PC
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Brother MFC 7420 All-In-One Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
