Question about Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher
Clean light flashing
The dishwasher does not start.if i press the start/reset....red light beeps and green clean light continues to flash/
please help
  • Anonymous Dec 26, 2008
    brand new dishwasher. Clean light flashing and dishwasher will not start.
  • 318 Answers
This is a safety failure of the unit not heating the water properly. if you push the " water heat, air dry, water heat, air dry" in that order, then it will go into the program mode and clear out that failure code.
then try the unit again, if you open the door during the heat cycle or it doesnt heat properly it will happen again. make sure you have hot enough water, 120 degrees, going to the unit and dont open the door after you start the cycle. if it continues call sears for service as it has a 1 year warranty.
Posted on Dec 28, 2008
4yr old Frigidaire, green flashing ER light and red flashing washing/drying and red flashing clean/S. model# PLD 4555RFC3. Also green flashing china/crystal and red flashing rinse/low, start/delay doesn't...
Good Afternoon Sandra, thank you for your question!
Let's try resetting the dishwasher by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn dishwasher back on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Sep 21, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
Green clean light is flashing, it will not clear and will not run because green light is flashing
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Jun 08, 2011 | Dishwashers
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The green light which goes off at the end of the cycle is continually flashing and there is a continual beep.
You may just need to reset your control board. Go to the link and it will explain how to reset the control board as well as explain what might cause the issue and how to fix it.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good Luck
Mar 06, 2011 | Whirlpool DU930 Built-in Dishwasher
Our "Clean" light is flashing green continuous and
Try running a cleaning cycle with no dishes. If you have hard water, try adding a little CLR, or cleaning solution. Check the bottom of the washer for clogged bottom drains. Also check the manual if you have it. Sometimes holding down the button for almost a minute will reset the systems alert for cleaning. Unplug and let it set for a few minutes. Good luck
Feb 21, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwasher will not start. The clean light is flashing on and off. If I push the cancel button it appears to be draining but there is no water in the tub and it just continues. When I push the start...
Kevin
Jan 20, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
How do i disconnect my HBH PV703 Headset from a damaged phone and connect it to another Phone
Step 1 - To reset your Bluetooth headset:
  1. Press and hold down the volume keys "+" and "-" on your headset at the same time, until your hear a beep and the light flashes red and green alternately.
  2. Press and hold down the volume keys on your headset until it is turned off. The headset is now reset as it was when purchased.
Step 2 - To pair the headset with your phone:
  1. Make sure the headset is turned off.
  2. Turn on the Bluetooth function and Bluetooth visibility in your phone (This makes the phone visible to other Bluetooth devices).
  3. Place the phone within 20 cm (8 inches) from the headset.
  4. Press and hold down the call handling key on the headset until it beeps, shows a steady green light and then flashes red and green alternately. If the indicator light only flashes red or green, simultaneously press and hold down both volume keys until the headset beeps and flashes red and green alternately.
  5. If your phone supports auto pairing, press "Yes" when you are asked to add the headset to the phone. If not, check your phone User Guide on how to pair the Bluetooth device. If required, the headset passcode is 0000.
  6. The headset beeps and flashes green when successfully paired.
Jan 21, 2009 | Audio Players & Recorders
CDA CW 446 dishwasher problem
Emma:
Is there a reset button on it? If so, press that. There are also sequences of buttons which one has to push to reset it. These are kept secret. Try pressing Hi Temp and Heated Dry, turn loose and press again within Five seconds. Or turn off the electricity and see if that resets it
May 11, 2008 | Dishwashers
Kenmore 24 in. 15173 Stainless Steel Built-in Dishwasher Logo
180 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
