Question about Whirlpool LER4634J Electric Dryer
Whirlpool Estate Dryer won't work
When you push the power button, there is a faint humming/ticking sound, but it doesn't start or turn. What could be the problem? I opened the dryer and the belt is still firm and secure.
  • 36 Answers
The thermal fuse on the back is probably out the humming is from the timer tale off the back panel and look for somthing that looks like this and test it for ohms http://us.st12.yimg.com/us.st.yimg.com/I/yhst-39356578169075_2030_2317267 it should read 0
Posted on Dec 09, 2008
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
I have a frigidaire gallery electric dryer. It was working fine for the load of laundry I had in it, then I put the next load in and turned the start button and all I get is a hum. It seems to be sending...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 16, 2011 | Frigidaire GLER331A Electric Dryer
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
When I pushed the start button on our dryer it made a funny noise and it sounded like sumething burned out. It just makes a mmmm sound when I try to start it and it won't turn on. It also kinda smelled...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Jan 31, 2011 | Estate EED4100SQ Electric Dryer
Dryer will not turn on. I hear a faint electrical sound when I push the start button but the dryer will not start. It worked fine through the last cycle. This is a stacked washer/dryer model & the...
Dryer Repair - The
Dryer Repair - The
heatman101
Aug 21, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer won't start. replaced the door switch & the push button switch still won't start. the light works when door is closed. can hear timer ticking like always.
It sounds like you have lost a leg of power. Turn off both breakers, then back on. Then check the receptacle, the plug and then the wiring to the back of the dryer. This is likely where it is. There is a thermal fuse located under the top of the dryer. Easy to get to. Bypass it and if it works then, just replace it for about 15 dollars.
Feb 03, 2009 | Whirlpool LER5636P Electric Dryer
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Whirlpool LER4634J Electric Dryer Logo
132 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
