Question about HP LaserJet 2420dn Printer
Hp laserjet 4220 Ready light is off , data light is green Attention light is red blinking . and i get paper out message , when i want to print , this printer is connected to my pc by Paralell port and there is no paper jam or missed paper . it worked till yesterday for three years .
  • 27 Answers
SOURCE: Blank print out
This is laser scanner error message. The document is not being read from the data being sent. This could be a loose or damaged cable or bad scanner assembly. You can open it up and look for loose cables or connections to the board but otherwise if the scanner assembly is bad, it may require replacement. This should only be accomplished by a service professional as it is not a user serviceable problem.
Posted on Jan 29, 2007
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
jaylex
  • 417 Answers
SOURCE: HP 4350 printer
EIO is the port for the network card on the back of the machine turn off machine remove card from EIO2 and install into EIO1 turn machine on and see what happens. If this does not work then open the formatter casing and remove the memory chips (OF COURSE WHEN THE MACHINE IS OFF) after removingone turn machine on and see if it boots up.
The 49 error is normally a software issue with the machine and it has locked within the network area or the memory.
Hope this helps you and please rate me
Cheers J
Posted on Dec 31, 2007
SOURCE: lights flashing, printer won't print as a result of a paper jam
Hi Girlemom. Just had the same problem here. Lift up the lid and slide the ink cartridges to the left. If they are stuck in the middle, this will prevent the printer from starting properly. Then, unplug it, plug back in, and turn on. It should restart normally.
Posted on May 21, 2009
  • 3278 Answers
SOURCE: The carriage is stalled message on my hp officejet H470 printer
Check the printer again to see if a very small jam is present. If totally clear, press the Resume button. If same result, power the printer Off / On.
Posted on Jun 28, 2009
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
Printer blinking red and showing letter E
Error description:
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out
-Door open
-Print cartridge missing
-Paper jam
-Paper sensor jammed
-Duplexer error
Solution :
After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
For more details visit the link below :
Resolve Printer issue
Jun 09, 2011 | HP DeskJet F380 All-In-One Printer
Hp laserjet 5200 the attention button red light won't stop blinking
This can be a number of reasons however I would be looking for a piece of paper jammed in the printer somewhere. Is the printer giving an error message or code?
If you turn the printer off, disconnect the printer cable, wait 5 minutes & then turn the printer back on, does it then power up & go to ready?
Apr 13, 2011 | HP LaserJet 2420 Printer
When I try to print the triangle with an exclamation point flashes and doesn't print
This is the 'Attention' light. It indicates that the cartridge door is open, or that other errors exist.
Not great info, but you need to methodically eliminate the possible causes of the error....
1. Try putting some paper into the Manual feed tray / slot. It may be waiting for you to feed paper manually. Check your printer driver settings....
2. Press the 'Go' button. It will make it print from Tray2
3. Check your Printer driver settings, and 'Page set up' in the application
4. Switch the device off, and unplug the data cable.
5.Switch it back on.
6. Print a configuration page from the printer control panel by pressing the Go button (the green one) until the green Ready and Error light start blinking.
7. If it prints these pages successfully, then the problem may be elsewhere (PC software, application, corrupt data, etc) but check the settings on the Configuration page as well.
Make sure they match your system, paper size and type, feeding options etc....
Dec 21, 2009 | HP LaserJet P2015dn Printer
Downloaded driver from HP. connected printer via
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
Dec 05, 2009 | HP LaserJet 2100tn Printer
THE ORANGE LIGHT IS ON AND NOT PRINTING
Blinking Attention Light HP LaserJet 1320 Series Printer - The printer displays an orange blinking attention light which will not clear. This usually indicates one of the following issues have occurred. Perform the following in the order provided to troubleshoot and resolve the issue.
1. Insufficient power. Disconnect the power cord from any surge protectors or power strips and plug the unit directly into an electrical wall outlet.
2. There is a paper jam in the printer.
3. The top cover is open. Open the top cover, reseat the print cartridge, and close the top cover, making certain it is shut properly.
4. No paper was loaded in tray 2 or the tray was not loaded properly causing a mispick. Perform the following steps to load tray 2.
A. Pull the tray out of the printer and remove any paper.
B. Move the blue side width guide outward to match the paper size that is being loaded. Locate the blue guide pointer on the left side of the tray. If using a letter-size (8.5 by 11 inch) paper, match the guide point with the LTR/LGL engraving located on the bottom, left-side of the lift plate.
C. Locate the blue tab on the rear paper-length guide. Locate the triangle-shaped pointer in the middle-right on the bottom of the tray. Press on the blue tab and adjust it so that the triangle-shaped pointer matches the paper size that is being loaded. If using letter-size (8.5 by 11 inch) paper, match the triangle-shaped pointer with the LTR engraving on the bottom of the tray.
D. Place the paper in the tray and make sure that it is flat at all four corners. Keep the paper below the height down arrows on the paper-length guide in the rear of the tray.
E. Slide the tray back in the printer.
5. The tray 2 paper level indicator is stuck.
6. If the printer comes back to a Ready state, print a Self-Test/Configuration page. If the printer is not in a Ready state, proceed to step 7.
A. Verify the printer is in a Ready state. (The green LED next to the U-shaped icon is on steady and no other lights are on.)
B. Press down on the green GO button until the orange Attention light comes on (approximately 5 seconds), and then immediately release the GO button. The green GO button will begin to blink and a Self-Test/Configuration page will print.
7. If the attention light is still on, perform a cold reset. A cold reset, sets most, but not all, default variables stored in NVRAM back to the factory default values. It typically does not reset the page count, paper tray sizes, localization language, or formatter number. Complete the following to perform a cold reset.
A. Turn the printer off.
B. Press and hold down the green GO button.
C. Turn the printer on and continue to hold the green GO button for at least 5 seconds, but not longer than 15 seconds. During the process, the Attention LED will turn on.
D. Release the GO button.
NOTE: If both the Attention light and the Ready LEDs turn on before the GO button is released, the cold reset procedure must be started over at step 1.
E. The printer LEDs begin cycling. The cold reset process runs until completion and the printer returns to the Ready state.
Oct 02, 2009 | HP LaserJet 1320n Printer
MY PRINTER : COLORJET 2550L DOES NOT START TO PRINT AND A RED LIGHT SHINES (NEXT TO THE GREEN ONE THAT SHOULD ). IT STARTS PRINTING ONLY AFTER I STRIKE THE FEEDED PAPER INTO THE PRINTER'S FEEDING TRAY. I...
Solution :
  1. Reinsert the print cartridge. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off and then back on again.
  2. If the problem persists, replace the cartridge. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off and then back on again.
  3. If the problem continues, contact HP Customer Care for technical support at http://www.hp.com/support/clj2500 or http://www.hp.com/support/clj1500 . Or see the flyer that came in the printer box for additional contact information.
Jul 26, 2009 | HP Color LaserJet 3500 Printer
I have a HP LaserJet 1320n printer and it will not print. An orange light keeps flashing by the triangle with an exclamation point in it. I printed a test page and it was okay. It will not print...
Possible Solution to your issue!
Feb 23, 2009 | HP LaserJet 1320n Printer
HP Laserjet 2015 dn
It means that the printer is in READY State.
Control panel
The printer control panel is comprised of six lights and two buttons. The lights produce patterns that
identify the printer status.
1 Jam light: Indicates that there is a jam in the printer.
2 Toner light: When the print cartridge is low, the Toner light illuminates. When the print cartridge is out of the printer,
the Toner light blinks.
3 Paper out light: Indicates that the printer is out of paper.
4 Attention light: Indicates that the print-cartridge door is open or other errors exist.
5 Ready light: Indicates that the printer is ready to print.
6 Go button and light: Initiates action or indicates status.
7 Cancel button: To cancel the print job that is currently printing, press the Cancel button.
Sep 08, 2008 | HP LaserJet P2015dn Printer
HP Laserjet 1320n Error Lights not in Manual
hi friends......
shivachadra is here.....just i faced this problem "Attention, Ready, and GO LEDs are on solid"
and i got solution in troubleshooting....just vi refixe the connetion of laser scanner........its the error of comunication between laser scanner and formatter....
May 27, 2008 | HP LaserJet 1320 Printer
HP LaserJet 2420dn Printer Logo
775 people viewed this question
Ben Johnson
