Acer Aspire 5720-4258 stuck in power save mode what do i do?
  • 2 more comments
  • appliance bo Dec 09, 2008
    The screen is still really dark i can still see the image to log on with and just by mere luck just loggged on but i can't see cursor it is like i need help to turn up the brightness when i hook up to a standalone monitor the monitor says it is in power save mode.
    i cant see to get to the control panel
    Whatare you calling a power adapter
    where do you get into the cmos settings
  • 107 Answers
Look on your keyboard see the secoundary blue keys,look around the f1 f2 f3 section or the arrow keys but none the less press down fn and look for the key that controlls screen brightness mine is the up and down keys but i also see a lot where it is an fn key but remeber to look before you push
Posted on Dec 09, 2008
  • 1 more comment
  • Eric Mitchell
    Eric Mitchell Dec 09, 2008
    Look around on you keyboard, see the blue secoundary stuff(look around the f1 f2 f3 ect.. area) a combonation of fn and another key controls your screen brightness so take a look around and try to find it, mine is the up and down keys some are f2 f3 some are page up and page down ect.. but If you find it and it still does not get brighter you need a new backlight or inverter so I hope this helps you (if you want me to see if I can help futher look me up athttp://www.crossloop.com/EricMitchell and just mention this post and I will help for free
  • Eric Mitchell
    I feel that I could help you better talking live so look me up on http://www.crossloop.com/EricMitchell (dont worry mention this and it
    will be free)
    Also
    chances are that the issue is a key combo, Fn plus another key on you
    keyboard it will be a secoundary key, look around on you keyboard see
    the blue symbles those are secoundary (not allways blue) So try that
    first if not let me know and I will try to help you further
  • Eric Mitchell
    sorry about the 3 post it did not show tell now
    Scholar:
  • 55 Answers
It means that your monitor is not reading any data from your computer. Unplug the VGA cable from your tower. Plug it back in. See if there's progress. The best thing to do to confirm if you have a monitor or a VGA cable problem is to try and plug in a known-good monitor and see if it works. If a known-good monitor does not work, then the problem is with your video card. If the video card is integrated, then the motherboard needs to be replaced.
Would appreciate if you'd rate this if this helped.
Thanks, ArnWuLF
  • 19,396 Answers
Check first the power saving settings from display properties.
Check if the AC charger connector is connecting properly, if the battery is charging, this means that you have a faulty inverter board.
    Sergeant:
    Champion:
  • 304 Answers
if your familiar with working with the CMOS settings, try to reset this settings. theres could be changes on the lcd backlight option on the settings.
keeps us updated.
  • 734 Answers
Please go to the above link to find out the solution ----
http://www.asklaptopfreak.com/laptop-notebook-help/2006/07/16/notebook-only-runs-off-the-battery/
Thanks
  • futureloginn
    futureloginn Dec 09, 2008
    I think it could be a bad DC jack. I do not work with Acer notebooks, so it would be only my guess. Try to plug in the AC adapter and wiggle the plug inside the jack. Can you make LEDs to flicker by wiggling the jack? Try to press on the power button while you are wiggling the power jack. If you notice that you can start the laptop when you apply some pressure on the power plug (and power jack), then most likely you have a power jack issue.
  • futureloginn
    futureloginn Dec 10, 2008
    please go to the above link to find out the solution ----
    http://www.asklaptopfreak.com/laptop-not...
    Sergeant:
  • 306 Answers
Unplug all inputs, then power back up. The monitor hovers in a moment of hesitation -- it really wants to "power save" -- then jumps to the panicked conclusion that there's ZERO input and gives a new floating screen with color bars. After that,  plug  laptop in, the monitor listens.
  • AbdulRahiman S Dec 09, 2008
    else go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option and Disable any power off mode on/ Sleep mode. It will solve your problem.
  • 162 Answers
Tried a power adapter ?
  • 4,806 Answers
If you are using vista, right click on the desktop and select "personalize" then click on "screen saver" at the bottom left click "Power options" and change the settings there.
kind regards
  • 2 more comments
  • Lee Hodgson
    Lee Hodgson Dec 09, 2008
    this sound like a classic case of graphics driver issue, what you need to do is boot into safe mode (press F8 on boot up) once in safe mode unistall the graphics drivers and restart the pc, you should now have a visible screen, if its vista you are using it will detect and reinstall the driver for you.
    If this does not work post back ASAP
    regads
  • Lee Hodgson
    To get into the bios restart the pc, as it is starting up hit F2 repeatedly
    why do you want to go into the bois anyway?
  • Lee Hodgson
    going into the bios/cmos will not solve the problem, its to do with the graphic drivers
  • Lee Hodgson
    read the post properly people this is a laptop not a desktop
  • 10,515 Answers
Try shifting ram around in the slots and it wld work fine.............
  • taran_2005
    taran_2005 Dec 09, 2008
    If that wld not work, follow :-
    ) Press and hold the power button for 8 seconds.
    2) Turn your computer on.
    3) If the computer says says "Windows was not shut down successfully" blah blah, just select "Start Windows Normally" with your arrow keys and press the "Enter" key.
    Thanks.
  • 1,879 Answers
Use a power adapter then go to control panel to change the power saving options
  • monk3ybidzness
    monk3ybidzness Dec 09, 2008
    possible causes:
    power supply - not enough power going to the monitor/screen
    or
    graphics card - no data/signal is received by the monitor/screen
    or
    try to clear cmos/bios
    it's a laptop - the last (clearing cmos/bios) suggestion can be tried as the first two requires service.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls remove battery battery and AC adapter/charge, wait 5 minutes and re-lug in the AC adapter/charger without the battery and try again. Soon as can confirm that the laptop works normally, log-off, power down/OFF, and remove AC adapter. Insert battery, plug-in charger, wait at least 30 minutes before trying again.
Pls post back any updates/development.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 09, 2008
    Appreciate the additional information.
    Accordingly on your 2nd post, you were able to view the message "power save mode" on an external monitor. Additionally, you could still see semblance of the laptop's display except that it is dark.
    Based on this, it is likely that the CCF (cold cathode florescent) lamp that serves as backlight is not turning on.
    I have to ask, did you try the force power OFF, remove battery, remove AC adapter?
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
Acer aspire z3750
hold down the ctr-alt-delete button same time should bring it out sleep mode and allow you to restart the pc. Once back on desktop go to power settings and turn sleep mode off.
Apr 20, 2014 | Acer Aspire Computers & Internet
Acer laptop stuck on Windows boot manager
1. Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
2. During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
3. Keep pressing the "F8" key until the "Advanced Boot Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode" selection.
The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
May 25, 2013 | Acer Aspire 5742Z-4601 : 2GHz Pentium...
Acer aspire t180 stuck on logo screen
try booting in safe mode by tapping f8 during boot
Oct 09, 2012 | Acer Aspire T180 PC Desktop
Help! My Laptop Acer Aspire One stuck at window logo loading Anyone please, help my acer aspire one stuck at window xp logo loading. I try everthing in F8 button, it didn't work, even in safe mod
oh a fun one. Reset your bios to defaults. if that doesn't work then try a windows disk boot up. if that doesn't work you're screwed.
if you want any of your files from the computer first pull out the hdd buy a cord and transfer them to another computer.
Sep 07, 2012 | Acer Aspire One PC Notebook
The cmos on my laptop(acer aspire 5536) was wiped and when i turned it on it wouldnt boot up just blank screen and a fan still works plus the power button still glows and the little yellow and blue lights...
yellow light indicates that it is offline mode/ log off/ power save mode/ hard reset by pressing power button for 10 sec and restart machine in safe mode that it could solve any h/w related problem
May 30, 2011 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire one stuck in safe mode
Turn the computer off. Hit the power button to turn it back on and as soon as you do start tapping the f8 button continuously until you get a list of options. Select the option "start windows normally"
Jan 14, 2010 | Acer Aspire One PC Notebook
My Acer One Aspire is stuck in hibernate. After it updated itself and said it was preparing to shut down, it was stuck in the preparing for shut down mode for hours. When I let the battery run down to turn...
This solution may sound stupid, but it is affective. Try to press really long time (about 1-2 minutes) on the power button of the laptop. wait for it to shut down completely. Then turn it on to see what happens.
What may have caused this is an update of any sort.
Nov 11, 2009 | Acer Aspire One PC Notebook
Ummm, hi. i was wondering how many watt my Acer Aspire 5600 runs?
Power
subsystem
ACPI 2.0 CPU power management standard: supports
Standby and Hibernation power-saving modes
71 W 8-cell or 44.4 W 6-cell Li-ion battery pack
Acer QuicCharge™ technology
(for Aspire 5600 Series):
• 80% charge in 1 hour
• 2-hour rapid charge system-off
• 2.5-hour charge-in-use
90/65 W AC adapter
Oct 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 3610 stuck in sleep mode
When you turn on your laptop do you see the P.O.S.T screen or it just remains blank? and also while booting up do you get any beep sound?
Try to boot your computer in Safe Mode by Tapping F2 (or Del in few laptops) key after pushing Power Button.
let me know what happens.
Askari :)
Mar 27, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 5100- Freeze when in Power Saver mode
try support.acer-euro.com
download very well download drivers
Mar 18, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
234 people viewed this question
David Payne
David Payne
