Question about ASUS P4GE-MX Motherboard
CMOS Setup Problem
Every time I turn on my PC, I\m always getting this message that my CMOS setup is incorrect and is restored to default values, my clock and date is also reset, is there a problem in my CMOS battery or someting else? My Mother board is P4GE-MX ASUS, and about the Memory issue last week tnx, but can my motherboard run a DDR PC400? if I will remove the other PC333 128 MB DDR RAM? tnx, tnx for always helping me, Iam so lucky i found a site like this to support my problems.
  • 21 Answers
Your cmos battery is bad,try and change it
Posted on Feb 26, 2007
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
Aspire 3690
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard drive.
  1. Verify your boot options are properly set in CMOS setup. We recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
  2. If your CMOS Setup has an option to boot from the LAN disable this option.
  3. If you have changed any CMOS settings, make sure to save and reboot the computer.
If this does not resolve the issue, try resetting the CMOS values to the default settings, save and exit.
Finally, if none of the above suggestions resolve this error go through the Invalid or Non System Disk error troubleshooting steps, which is related to this error message.
Dec 17, 2013 | Acer Aspire Computers & Internet
GX150 optiflex "setup utility" configuration
OPERATING SYSTEM. That would be Windows.
You are in BIOS Setup, and shouldn't be in there.
Computer OFF. (Press the Power On button, and hold it for 10 seconds until the computer turns off; if it is on)
Press the Power On button, and hold it in. Hold for a count of 10 seconds. let go. Do this same procedure 2 more times.
If the Power On LED light blinks, when you press the Power On button for the third time; hold for ten seconds, let go; do it again.
Keep pressing until the Power On LED light doesn't blink on.
This resets CMOS Error Codes, and resets BIOS Setup back to the factory default settings.
Operating system error is solved by installing the Restoration Disk/s, and when asked choose Repair. (Non-Destructive Installation)
If this doesn't solve the problem, you have a bad harddrive data cable, or a bad harddrive.
Regards,
joecoolvette
Nov 19, 2012 | Dell OptiPlex GX150 SF PC Desktop
Reset CMOS on IBM 2847
  1. cmossave.jpgEnter CMOS setup.
  2. In CMOS setup look for an option to reset the CMOS values to the default setting or an option to load the fail-safe defaults. With many CMOS setup screens there will be a function key to do this; for example, the F5, F6, F9, F11, or F12 key like shown in the picture to the right. Other setups may actually list an option that you can arrow over to using the arrow keys and press Enter.
  3. When found and selected you'll likely be asked if you're sure you wish to load the defaults press Y for yes or arrow to the yes option.
  4. Once the default values have been set make sure to Save and Exit and not just exit.
May 14, 2012 | IBM Computers & Internet
Laptop wont start
This issue is often caused by either an incorrect setting in CMOS Setup or a bad boot device, such as a bad hard disk drive.
  1. Verify your boot options are properly set in CMOS setup. I recommend having the CD or disc drive as your first boot device and then hard drive as the second boot device.
If this fixes the problem but it reoccurs again later you main need a new cmos battery. Or keep your battery always slightly charged.
Nov 16, 2011 | Toshiba Computers & Internet
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Cmos
You need to press F1 and go into the BIOS to setup and detect everything. You will need to set the date, verify it detects your hard drive and memory, and enable/disable items as you need for your system.
Once it looks good, do a Save and Exit.
Jan 16, 2009 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
1. New hardware has been recently installed.
2. Error or confliction with settings in CMOS.
3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS.
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Bios checksum error. How to solve it?
If you are using an old computer, there’s a possibility that you already encountered this error message during bootup; “CMOS checksum error – Defaults loaded”. At this point, the PC will halt its operation and requires you to press F1 to continue or DEL to enter setup (mostly but also depends on motherboard) to proceed.
This is caused by incorrect or corrupted CMOS values. BIOS settings are stored in CMOS. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, the error message will be displayed.
For most cases, this is caused by the motherboard battery. Buy a new one to any electronic retailers in your area and replace it. Turn on your computer and press the stated key to enter the BIOS setup. It can be DEL for some or F2 but this depends on your computer. On the BIOS menu, try to change the DATE and TIME settings because their values are reset to different value. Most settings are set to default so leave it as it is. Save the settings and reboot your computer.
Oct 04, 2008 | MSI PM8M-V Motherboard
ASUS P4GE-MX Motherboard Logo
180 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
