Question about Neff U1421 Double circotherm Electric Oven
Oven hotter at the back
My oven has supposedly been fixed numerous times but it still gets much hotter at the back than the front and whatever is facing the back of the oven burns....half a cake, turkey whatever. very frustrating. Any idea what would cause this and how to fix it??? thank you
  • Neff Master
  • 3,463 Answers
You should always preheat oven to operating temperature before cooking anything.
Do not put too much in oven, leave plenty af space for good air circulation.
Do not place any reflective foil or the like on the bottom of oven or shelves, as this reflects heat, and you will get uneven cooking.
Make sure fan is working efficiently if it is fan assisted.
Posted on Jan 15, 2009
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
Oven is hotter in the back of the over than the
Good Afternoon Essie, thank you for your post!
So I understand you're staying that the oven has a higher temperature in the front, is that correct? If so, technically speaking that is very rare or not possible. I suggest to make sure the pan is placed in the middle of the rack and not closer to the front or back. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you!
Nov 03, 2013 | Frigidaire 30 in. Electric Gallery Series...
Oven set at 350 goes way higher
the oven sensor rod on the rear wall of the oven cavity is defective,remove screws holding it sometimes you can plug a new replacement sensor in from the front,if you can't then remove rear panel on the back of the oven to access the connector to replace it
Nov 26, 2012 | Ovens
Over heating fan oven
it sounds like you tod is faulty its the little stat at the back on the right hand side two wires going to it ok make sure to swicth oven off
Oct 14, 2012 | DeLonghi Ovens
When using the oven setting it justs get hotter and hotter.
tt sounds like the thermostat sensor
Dec 27, 2009 | Ovens
The sides and front of my oven get extremely hot, why? I am afraid to use the oven in fear it will burn the cabinets next to it. The oven is not self cleaning, is this why it is getting hot? My last oven...
Normally oven gets hot but just lukewarm externally(front and sides). Compare it when it
was still new. If it is hotter than it was, then the insulation inside have deteriorated thru time. Have it check for possible insulation replacement Hope this will solve your problem. Don't forget to vote for me. Thanks.
Sep 22, 2009 | Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
Oven temp gets hotter than control indicates.
Alot of the thermostats are adjustable and can be recalibrated but when they act like this, it is best to replace them. It is just a matter of time before it quit all together. Electronic units are some what different.
Let me know what you do and I'll give you a hand in getting it going.
May 09, 2009 | Ovens
Oven works intermittently
well i had a service call like this one time almost drove me crazy lol so to try to help im going to tell you about it every thing checked out but oven would not cook right finnaly i took the gasline loose from the regulator and rust and trash had built up so heavy on the regulator screen it was restictin the flow of gas so when the contol demanded more gas it couldnt get it but it wouldnt set a fault code because nothing were wrong with the conterols
Dec 11, 2007 | KitchenAid Architect Series KEBC107KSS...
Electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Apr 16, 2007 | Neff U1421 Double circotherm Electric Oven
Neff U1421 Double circotherm Electric Oven Logo
439 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
